Results 1 to 4 of 4
Thread: Revit Eats up Huge amounts of Memory To a complete Stall
    December 27, 2016
    1
    10:08 PM
    Hi all,
    I'm Using Revit Architecture 2013, after I open a VERY simple 5MB project in revit, it starts to eat up my memory starting from 300+ MB up to 7~9 GB in just one hour of very simple work, and finally slows to a drag and crashes reporting I'm low on my system memory. I've seen other threads pointing at 20xfile size memory usage by revit, but that is not my case because the total amount of files i opened were 20 MB, thus needs a 400+MB memory, but revit gets over 7 and up to 9 GB.
    I'm on Windows 7 Ultimate 64 with core i7 laptop
    With 16GB RAM
    NVIDIA GeForce GT 540M
    Please Help.
    to see how the memory is used up, look at these task manager snapshots taken every 15 minutes working on two files, one 5 MB and the othe 15 MB:
    then after some 40 minutes, without opening any new or large files:
    there's a copy of the journal files attached
    BTW I'm an expert Autocad User, But A rookie in Revit.
    Attached Thumbnails Attached Thumbnails Revit Eats up Huge amounts of Memory To a complete Stall-1.jpg   Revit Eats up Huge amounts of Memory To a complete Stall-3.jpg
    Attached Files Attached Files
    Member Darius's Avatar
    May 6, 2013
    468
    06:08 PM
    a couple things
    First is you are using revit 2013 you will not be able to open files off any of the newer versions of revit 2014 and up
    Adesk won't help you with this problems as it is more than 3 releases from the current version
    if i recall correctly this was a problem with 2013 and the amount of resources it uses which was cleaned up some in later releases however Revit will always use more resources than acad
    - - - Updated - - -
    a couple things
    - - - Updated - - -
    a couple things
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    297
    03:08 PM
    I would verify that you have the most current update for Revit Architecture 2013:
    RAC 2013 Service Pack 3 (UR3) 12.11.10090 20130531_2115
    Gold Coast
    2,265
    08:08 AM
    Quote Originally Posted by Darius View Post
    a couple things
    - - - Updated - - -
    a couple things
    - - - Updated - - -
    a couple things
    Whoa, we're triple posting now? And I was just getting used to doubles
  1. Huge revit template
    By ljakubowski in forum Architecture and General Revit Questions
    Last Post: December 2nd, 2015, 10:11 PM
  2. Revit using hight amounts of disk memory
    By Alecsx in forum Architecture and General Revit Questions
    Last Post: July 27th, 2015, 02:23 PM
  3. revit .dmp file huge
    By DaneHitchins in forum Hardware and Infrastructure
    Last Post: November 14th, 2013, 02:43 PM
  4. I've installed my revit software but its not complete! how can i complete it?
    By smshiran in forum Architecture and General Revit Questions
    Last Post: November 19th, 2012, 03:48 PM
  5. Revit 2012 Eats Memory!!
    By jgrasp in forum Hardware and Infrastructure
    Last Post: July 30th, 2012, 03:55 AM
