Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 67
Like Tree5Likes
Thread: RFO Benchmark v3 2017 results
    Rotterdam, South Holland
    2,998
    02:14 PM
    Please post your RFOBenchmark V3 results for the 2017 products here.
    Comments and suggestions should be made in the RFOBenchmark v3 thread. The download is there too.
    Thanks!
    Gordon
    November 3, 2015
    24
    12:14 PM
    This is my standard RFO 2017 test:
    RVT 2017 - Standard set - 2016.10.18 @ 22.47.51 on LAPTOP-F4TBSSEJ
    RFO Benchmark v3.0 (build 17.10.2016)
    RevitForum.org
    All times are in seconds, lower is better.
    Run on Autodesk Revit 2017 SP1
    __________________________________________________ _______________
    Update
    13.97 update previous version file
    Model creation benchmark
    4.40 opening and loading the custom template
    19.59 creating the floors levels and grids
    28.67 creating a group of walls and doors
    43.50 modifying the group by adding a curtain wall
    17.17 creating the exterior curtain wall
    13.02 creating the sections
    5.34 changing the curtain wall panel type
    14.20 creating area plans
    1.89 creating and applying view template
    147.78 TOTAL
    Export benchmark
    86.70 export all views as PNGs at 300 dpi
    107.27 export all views as DWFs
    177.75 export all views as DWGs
    98.64 print all views as vector *
    125.85 print all views as raster *
    Notes:
    * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
    92.80 render
    Graphics benchmark
    5.53 refresh Hidden Line view x12
    5.52 refresh Consistent Colors view x12
    6.79 refresh Realistic view x12
    4.04 rotate view x1
    Notes:
    Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    To meaningfully compare graphics cards, test all cards in the same machine
    and use the 'Graphics - expanded' benchmark.
    Raw Data
    13.602 14.094 14.227 update previous version file
    3.828 4.711 4.664 opening and loading the custom template
    16.211 21.578 20.977 creating the floors levels and grids
    25.461 29.367 31.188 creating a group of walls and doors
    41.570 44.148 44.773 modifying the group by adding a curtain wall
    14.648 18.305 18.570 creating the exterior curtain wall
    12.727 13.352 12.977 creating the sections
    4.992 5.664 5.372 changing the curtain wall panel type
    13.242 15.586 13.783 creating area plans
    1.961 2.086 1.633 creating and applying view template
    86.555 86.586 86.957 export all views as PNGs at 300 dpi
    107.477 106.836 107.498 export all views as DWFs
    179.531 177.844 175.871 export all views as DWGs
    98.539 97.945 99.424 print all views as vector
    131.422 130.414 115.719 print all views as raster
    94.492 93.477 90.446 render
    5.680 5.414 5.504 refresh Hidden Line view x12
    5.469 5.539 5.566 refresh Consistent Colors view x12
    6.812 6.750 6.793 refresh Realistic view x12
    4.023 4.164 3.932 rotate view x1
    TEST CONDITIONS:
    Mfr: LENOVO
    Model: 80NV
    OS: Microsoft Windows 10 Home64-bit
    CPU: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
    Max Clock Speed: 2.601Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 2133 2133Mhz
    April 24, 2014
    Brisbane, Australia
    20
    10:14 PM
    RVT 2017 - Standard set - 2016.10.20 @ 09.30.21 on 091006-02
    RevitForum.org
    Run on Autodesk Revit 2017.1
    Update
    14.18 update previous version file
    2.91 opening and loading the custom template
    11.01 creating the floors levels and grids
    28.74 creating a group of walls and doors
    61.67 modifying the group by adding a curtain wall
    18.12 creating the exterior curtain wall
    9.86 creating the sections
    5.79 changing the curtain wall panel type
    11.30 creating area plans
    1.83 creating and applying view template
    151.23 TOTAL
    Export benchmark
    99.89 export all views as PNGs at 300 dpi
    82.01 export all views as DWFs
    166.79 export all views as DWGs
    95.50 print all views as vector *
    146.07 print all views as raster *
    Notes:
    Render benchmark
    131.17 render
    Graphics benchmark
    0.08 refresh Hidden Line view x12
    0.05 refresh Consistent Colors view x12
    0.05 refresh Realistic view x12
    1.66 rotate view x1
    Notes:
    Raw Data
    15.992 13.223 13.324 update previous version file
    3.254 2.723 2.742 opening and loading the custom template
    12.516 10.461 10.039 creating the floors levels and grids
    30.340 27.770 28.121 creating a group of walls and doors
    61.766 60.730 62.508 modifying the group by adding a curtain wall
    18.113 17.207 19.055 creating the exterior curtain wall
    10.973 9.121 9.480 creating the sections
    6.438 5.340 5.598 changing the curtain wall panel type
    13.418 10.207 10.266 creating area plans
    1.871 2.047 1.582 creating and applying view template
    97.590 103.090 99.004 export all views as PNGs at 300 dpi
    80.305 81.707 84.020 export all views as DWFs
    169.109 167.523 163.734 export all views as DWGs
    94.809 95.856 95.840 print all views as vector
    144.555 149.113 144.527 print all views as raster
    127.172 134.508 131.836 render
    0.066 0.078 0.082 refresh Hidden Line view x12
    0.047 0.051 0.055 refresh Consistent Colors view x12
    0.051 0.055 0.059 refresh Realistic view x12
    1.637 1.582 1.770 rotate view x1
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    OS: Microsoft Windows 7 Professional 64-bit
    CPU: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz
    Max Clock Speed: 3.201Ghz
    Total Physical Memory: 16GB @ Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 840 EVO 250GB ATA Device
    Graphics Card: AMD Radeon HD 5800 Series
    Graphics RAM: 1GB
    Driver version: 15.200.1046.0
    Screen Resolution: 1920x1200x32bit @ 60Hz
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    246
    02:14 PM
    Code:
    RVT 2017 - Standard set - 2016.11.18 @ 18.00.02 on ZBOOKG3
         RevitForum.org
     _________________________________________________________________
     Update
        12.16   update previous version file
         3.23   opening and loading the custom template
        13.06   creating the floors levels and grids
        22.71   creating a group of walls and doors
        41.09   modifying the group by adding a curtain wall
        13.33   creating the exterior curtain wall
        10.80   creating the sections
         4.38   changing the curtain wall panel type
        12.10   creating area plans
         1.45   creating and applying view template
       122.15   TOTAL
     Export benchmark
        74.91   export all views as PNGs at 300 dpi
        55.32   export all views as DWFs
       106.02   export all views as DWGs
        64.85   print all views as vector *
       112.75   print all views as raster *
     Notes:
     Render benchmark
        99.73   render
     Graphics benchmark
         5.82   refresh Hidden Line view x12
         5.73   refresh Consistent Colors view x12
         7.12   refresh Realistic view x12
         3.09   rotate view x1
     Notes:
     Raw Data
       13.062   11.750   11.672   update previous version file
        3.223    3.227    3.242   opening and loading the custom template
       13.512   12.797   12.859   creating the floors levels and grids
       23.070   22.656   22.398   creating a group of walls and doors
       41.465   40.953   40.852   modifying the group by adding a curtain wall
       13.574   13.414   13.000   creating the exterior curtain wall
       10.773   10.938   10.680   creating the sections
        4.434    4.445    4.266   changing the curtain wall panel type
       12.125   12.109   12.062   creating area plans
        1.438    1.445    1.469   creating and applying view template
       74.980   74.695   75.055   export all views as PNGs at 300 dpi
       55.273   56.203   54.469   export all views as DWFs
      107.797  104.922  105.328   export all views as DWGs
       64.773   64.766   65.000   print all views as vector
      112.422  112.234  113.594   print all views as raster
      109.508   94.984   94.711   render
        5.852    5.812    5.805   refresh Hidden Line view x12
        5.719    5.781    5.688   refresh Consistent Colors view x12
        7.109    7.172    7.070   refresh Realistic view x12
        3.039    3.133    3.094   rotate view x1
     TEST CONDITIONS:
     Mfr: HP
     Model: HP ZBook 15 G3
     Drive Model: NVMe THNSN5512GPU7 TO SCSI Disk Device
     Graphics Card: NVIDIA Quadro M1000M
     Graphics RAM: 2GB
     Driver version: 10.18.13.5649
     Graphics Card: Intel(R) HD Graphics 530
     Graphics RAM: 1GB
     Driver version: 20.19.15.4483
     Screen Resolution: xx32bit @ Hz
    New Member MasterOfKonstrakszyn's Avatar
    January 19, 2015
    Warszawa
    2
    12:14 PM
    RVT 2017 - Standard set - 2016.11.18 @ 21.52.23 on TOMEK-LAPTOP
    RevitForum.org
    Run on Autodesk Revit 2017 SP2
    Update
    14.72 update previous version file
    3.85 opening and loading the custom template
    15.08 creating the floors levels and grids
    25.56 creating a group of walls and doors
    43.45 modifying the group by adding a curtain wall
    15.78 creating the exterior curtain wall
    11.57 creating the sections
    5.56 changing the curtain wall panel type
    12.72 creating area plans
    1.74 creating and applying view template
    135.31 TOTAL
    Export benchmark
    78.87 export all views as PNGs at 300 dpi
    153.57 export all views as DWFs
    173.16 export all views as DWGs
    86.90 print all views as vector *
    116.38 print all views as raster *
    Notes:
    Render benchmark
    193.10 render
    Graphics benchmark
    6.86 refresh Hidden Line view x12
    6.77 refresh Consistent Colors view x12
    8.05 refresh Realistic view x12
    4.75 rotate view x1
    Notes:
    Raw Data
    13.586 16.445 14.133 update previous version file
    3.781 3.875 3.883 opening and loading the custom template
    14.914 15.125 15.203 creating the floors levels and grids
    25.719 24.930 26.039 creating a group of walls and doors
    43.602 43.328 43.422 modifying the group by adding a curtain wall
    15.930 15.742 15.664 creating the exterior curtain wall
    11.664 11.422 11.633 creating the sections
    5.523 5.516 5.641 changing the curtain wall panel type
    12.695 12.805 12.648 creating area plans
    1.734 1.773 1.727 creating and applying view template
    77.797 79.977 78.844 export all views as PNGs at 300 dpi
    153.852 156.305 150.562 export all views as DWFs
    174.461 173.469 171.547 export all views as DWGs
    86.648 87.688 86.367 print all views as vector
    115.922 118.367 114.852 print all views as raster
    212.234 182.609 184.445 render
    6.969 6.914 6.711 refresh Hidden Line view x12
    6.617 6.789 6.891 refresh Consistent Colors view x12
    7.906 8.242 8.016 refresh Realistic view x12
    5.180 4.906 4.156 rotate view x1
    TEST CONDITIONS:
    Mfr: Acer
    Model: Aspire VN7-591G
    CPU: Intel(R) Core(TM) i5-4210H CPU @ 2.90GHz
    Max Clock Speed: 2.901Ghz
    Number of Processors: 2
    Number of Logical Processors: 4
    Total Physical Memory: 8GB @ 1600Mhz
    Drive Model: KINGSTON SM2280S3120G
    Graphics Card: NVIDIA GeForce GTX 860M
    Graphics RAM: 2GB
    Driver version: 21.21.13.6909
    Graphics Card: Intel(R) HD Graphics 4600
    Graphics RAM: 1GB
    Driver version: 10.18.15.4248
    Screen Resolution: 1920x 1200x32bit @ 59Hz
    March 8, 2011
    Zagreb, Croatia
    246
    02:14 PM
    Code:
     RVT 2017 - Standard set - 2016.11.18 @ 08.45.12 on I7-4770WS
         RevitForum.org
     Update
        12.18   update previous version file
         3.43   opening and loading the custom template
        11.68   creating the floors levels and grids
        21.04   creating a group of walls and doors
        35.78   modifying the group by adding a curtain wall
        13.88   creating the exterior curtain wall
        10.14   creating the sections
         4.57   changing the curtain wall panel type
        11.17   creating area plans
         1.61   creating and applying view template
       113.30   TOTAL
     Export benchmark
        69.18   export all views as PNGs at 300 dpi
        49.03   export all views as DWFs
       113.59   export all views as DWGs
        81.35   print all views as vector *
       121.44   print all views as raster *
     Notes:
     Render benchmark
        84.29   render
     Graphics benchmark
         5.26   refresh Hidden Line view x12
         5.30   refresh Consistent Colors view x12
         6.36   refresh Realistic view x12
         2.45   rotate view x1
     Notes:
     Raw Data
       13.066   11.727   11.746   update previous version file
        3.445    3.246    3.594   opening and loading the custom template
       11.447   11.906   11.688   creating the floors levels and grids
       20.957   21.070   21.078   creating a group of walls and doors
       36.238   35.262   35.852   modifying the group by adding a curtain wall
       13.980   13.797   13.867   creating the exterior curtain wall
       10.031   10.156   10.227   creating the sections
        4.529    4.594    4.598   changing the curtain wall panel type
       11.162   11.094   11.266   creating area plans
        1.572    1.644    1.613   creating and applying view template
       69.467   68.953   69.113   export all views as PNGs at 300 dpi
       49.514   48.711   48.856   export all views as DWFs
      113.576  113.215  113.969   export all views as DWGs
       81.641   80.934   81.469   print all views as vector
      121.434  121.394  121.500   print all views as raster
       80.164   80.207   92.484   render
        5.262    5.246    5.281   refresh Hidden Line view x12
        5.328    5.250    5.336   refresh Consistent Colors view x12
        6.387    6.332    6.363   refresh Realistic view x12
        2.500    2.445    2.391   rotate view x1
     TEST CONDITIONS:
     Mfr: To Be Filled By O.E.M.
     Model: To Be Filled By O.E.M.
     OS: Microsoft Windows 10 Pro64-bit
     CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
     Max Clock Speed: 3.401Ghz
     Total Physical Memory: 16GB @ 1333 1333Mhz
     Graphics Card: NVIDIA GeForce GTX 760
     Graphics RAM: 2GB
     Driver version: 21.21.13.7270
     Graphics RAM: 1GB
     Driver version: 20.19.15.4531
     Screen Resolution: 2560 1600x1440 1200x32bit @ 59 60Hz
    9,067
    07:14 AM
    My main workhouse (laptop), running on 2560x1440:
    Quote Originally Posted by RFO Benchmark v3.0
    RVT 2017 - Standard set - 2016.11.19 @ 10.38.00 on PRLX751001
    RevitForum.org
    Update
    9.30 update previous version file
    3.87 opening and loading the custom template
    14.80 creating the floors levels and grids
    24.96 creating a group of walls and doors
    43.41 modifying the group by adding a curtain wall
    14.15 creating the exterior curtain wall
    12.23 creating the sections
    4.93 changing the curtain wall panel type
    11.78 creating area plans
    1.85 creating and applying view template
    131.98 TOTAL
    Export benchmark
    77.95 export all views as PNGs at 300 dpi
    59.12 export all views as DWFs
    128.50 export all views as DWGs
    68.90 print all views as vector *
    108.76 print all views as raster *
    Notes:
    Render benchmark
    92.65 render
    Graphics benchmark
    5.51 refresh Hidden Line view x12
    5.54 refresh Consistent Colors view x12
    6.76 refresh Realistic view x12
    4.62 rotate view x1
    Notes:
    Raw Data
    14.590 13.316 update previous version file
    3.863 3.926 3.832 opening and loading the custom template
    13.949 15.910 14.531 creating the floors levels and grids
    23.691 26.902 24.277 creating a group of walls and doors
    43.559 42.863 43.805 modifying the group by adding a curtain wall
    13.555 14.309 14.578 creating the exterior curtain wall
    12.625 11.066 12.988 creating the sections
    4.762 5.000 5.031 changing the curtain wall panel type
    11.594 11.934 11.812 creating area plans
    1.863 1.828 1.856 creating and applying view template
    78.062 77.789 78.012 export all views as PNGs at 300 dpi
    59.574 58.738 59.059 export all views as DWFs
    129.469 127.867 128.168 export all views as DWGs
    68.438 68.832 69.430 print all views as vector
    106.809 107.426 112.055 print all views as raster
    84.207 97.113 96.621 render
    5.457 5.531 5.543 refresh Hidden Line view x12
    5.520 5.520 5.586 refresh Consistent Colors view x12
    6.742 6.730 6.816 refresh Realistic view x12
    4.594 4.637 4.633 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision 7510
    CPU: Intel(R) Core(TM) i7-6920HQ CPU @ 2.90GHz
    Max Clock Speed: 2.904Ghz
    Total Physical Memory: 64GB @ 2133 2133 2133 2133Mhz
    Drive Type: Network Drive
    Drive Model: Not Available
    Graphics RAM: 1GB
    Graphics Card: NVIDIA Quadro M2000M
    Graphics RAM: 3.9990234375GB
    Screen Resolution: 2560 2560x1440 1440x32bit @ 59 59Hz
    EDIT: Previous benchmark results were a mistake, because of an error. This is now the correct run, using v3.
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    297
    05:14 AM
    RVT 2017 - Standard set - 2016.11.16 @ 08.32.59 on SEA-????-1
    RevitForum.org
    Update
    13.13 update previous version file
    2.86 opening and loading the custom template
    10.01 creating the floors levels and grids
    27.33 creating a group of walls and doors
    58.58 modifying the group by adding a curtain wall
    14.76 creating the exterior curtain wall
    8.33 creating the sections
    5.06 changing the curtain wall panel type
    9.33 creating area plans
    1.53 creating and applying view template
    137.79 TOTAL
    Export benchmark
    87.16 export all views as PNGs at 300 dpi
    81.23 export all views as DWFs
    161.72 export all views as DWGs
    94.02 print all views as vector *
    164.69 print all views as raster *
    Notes:
    Render benchmark
    39.07 render
    Graphics benchmark
    0.07 refresh Hidden Line view x12
    0.04 refresh Consistent Colors view x12
    0.04 refresh Realistic view x12
    1.49 rotate view x1
    Notes:
    Raw Data
    13.371 13.006 13.027 update previous version file
    2.848 2.865 2.871 opening and loading the custom template
    10.324 9.805 9.910 creating the floors levels and grids
    27.734 27.144 27.117 creating a group of walls and doors
    59.080 58.656 58.012 modifying the group by adding a curtain wall
    15.049 14.625 14.609 creating the exterior curtain wall
    8.373 8.348 8.273 creating the sections
    5.141 4.988 5.039 changing the curtain wall panel type
    9.562 9.285 9.137 creating area plans
    1.557 1.469 1.551 creating and applying view template
    86.455 87.199 87.824 export all views as PNGs at 300 dpi
    81.336 80.719 81.637 export all views as DWFs
    161.113 162.852 161.199 export all views as DWGs
    93.953 94.473 93.641 print all views as vector
    163.301 166.336 164.426 print all views as raster
    39.363 38.770 39.078 render
    0.066 0.066 0.062 refresh Hidden Line view x12
    0.045 0.043 0.043 refresh Consistent Colors view x12
    0.041 0.043 0.039 refresh Realistic view x12
    1.482 1.418 1.562 rotate view x1
    TEST CONDITIONS:
    Mfr: HP
    Model: ProLiant SL250s Gen8
    OS: Microsoft Windows Server 2008 R2 Datacenter -bit
    CPU:
    Max Clock Speed: 0Ghz
    Total Physical Memory: 128GB @ Mhz
    Drive Model: HP LOGICAL VOLUME SCSI Disk Device
    Graphics Card: Mirage Driver
    Graphics RAM: 0GB
    Driver version: 2.0.105.0
    Graphics Card: NVIDIA Tesla M2070-Q
    Driver version: 9.18.13.1135
    Graphics Card: Matrox G200eH (HP)
    Graphics RAM: 0GB
    Driver version: 1.2.1.0
    July 27, 2012
    297
    05:14 AM
    RVT 2017 - Standard set - 2016.11.21 @ 12.46.09 on SEA-L13-???????
    RevitForum.org
    Update
    19.56 update previous version file
    4.32 opening and loading the custom template
    19.96 creating the floors levels and grids
    38.71 creating a group of walls and doors
    72.30 modifying the group by adding a curtain wall
    23.79 creating the exterior curtain wall
    17.89 creating the sections
    8.26 changing the curtain wall panel type
    20.35 creating area plans
    2.88 creating and applying view template
    208.46 TOTAL
    Export benchmark
    90.22 export all views as PNGs at 300 dpi
    95.86 export all views as DWFs
    177.55 export all views as DWGs
    105.56 print all views as vector *
    169.40 print all views as raster *
    Notes:
    Render benchmark
    174.19 render
    Graphics benchmark
    11.28 refresh Hidden Line view x12
    11.42 refresh Consistent Colors view x12
    14.19 refresh Realistic view x12
    3.40 rotate view x1
    Notes:
    Raw Data
    20.574 19.074 19.023 update previous version file
    4.297 4.336 4.328 opening and loading the custom template
    20.098 19.840 19.930 creating the floors levels and grids
    38.363 38.680 39.082 creating a group of walls and doors
    76.371 70.695 69.848 modifying the group by adding a curtain wall
    24.406 23.438 23.535 creating the exterior curtain wall
    18.512 17.383 17.770 creating the sections
    8.320 8.106 8.344 changing the curtain wall panel type
    20.856 19.535 20.672 creating area plans
    3.004 2.742 2.891 creating and applying view template
    89.043 87.281 94.332 export all views as PNGs at 300 dpi
    100.336 88.480 98.777 export all views as DWFs
    178.910 169.570 184.168 export all views as DWGs
    109.547 102.590 104.543 print all views as vector
    176.809 164.957 166.441 print all views as raster
    169.113 156.367 197.102 render
    11.586 11.125 11.141 refresh Hidden Line view x12
    11.098 11.148 12.000 refresh Consistent Colors view x12
    13.977 13.598 14.988 refresh Realistic view x12
    3.367 3.422 3.422 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision M4600
    OS: Microsoft Windows 10 Enterprise64-bit
    CPU: Intel(R) Core(TM) i7-2760QM CPU @ 2.40GHz
    Max Clock Speed: 2.401Ghz
    Total Physical Memory: 16GB @ 1333 1333 1333 1333Mhz
    Drive Model: Samsung SSD 840 Series
    Graphics Card: NVIDIA Quadro 2000M
    Graphics RAM: 2GB
    Driver version: 9.18.13.3221
    Graphics Card: Intel(R) HD Graphics 3000
    Graphics RAM: 2.05859375GB
    Driver version: 9.17.10.3517
    Screen Resolution: 1920 1920x1080 1200x32bit @ 60 59Hz
    October 15, 2011
    3
    12:14 PM
    RVT 2017 - Standard set - 2016.12.02 @ 19.03.07 on SMOKU
    RevitForum.org
    Run on Autodesk Revit 2017.1.1
    Update
    9.57 update previous version file
    2.67 opening and loading the custom template
    8.93 creating the floors levels and grids
    16.59 creating a group of walls and doors
    30.47 modifying the group by adding a curtain wall
    9.41 creating the exterior curtain wall
    7.02 creating the sections
    3.26 changing the curtain wall panel type
    8.01 creating area plans
    1.13 creating and applying view template
    87.49 TOTAL
    Export benchmark
    53.32 export all views as PNGs at 300 dpi
    40.04 export all views as DWFs
    110.24 export all views as DWGs
    48.94 print all views as vector *
    82.47 print all views as raster *
    Notes:
    Render benchmark
    68.49 render
    Graphics benchmark
    4.04 refresh Hidden Line view x12
    4.08 refresh Consistent Colors view x12
    4.99 refresh Realistic view x12
    1.53 rotate view x1
    Notes:
    Raw Data
    9.930 9.359 9.422 update previous version file
    2.680 2.680 2.656 opening and loading the custom template
    9.094 8.859 8.836 creating the floors levels and grids
    16.586 16.625 16.562 creating a group of walls and doors
    30.539 30.492 30.383 modifying the group by adding a curtain wall
    9.406 9.414 9.422 creating the exterior curtain wall
    7.047 7.023 6.977 creating the sections
    3.273 3.281 3.234 changing the curtain wall panel type
    8.016 8.102 7.922 creating area plans
    1.188 1.117 1.094 creating and applying view template
    53.484 53.312 53.156 export all views as PNGs at 300 dpi
    40.039 39.961 40.133 export all views as DWFs
    110.234 110.297 110.180 export all views as DWGs
    49.000 48.859 48.953 print all views as vector
    82.445 82.414 82.539 print all views as raster
    65.500 65.000 74.969 render
    4.062 4.031 4.039 refresh Hidden Line view x12
    4.078 4.094 4.078 refresh Consistent Colors view x12
    5.008 5.008 4.953 refresh Realistic view x12
    1.547 1.492 1.555 rotate view x1
    TEST CONDITIONS:
    CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
    Max Clock Speed: 4.001Ghz
    Total Physical Memory: 16GB @ 3000 3000Mhz
    Drive Model: Samsung SSD 850 EVO M.2 250GB
    Graphics Card: NVIDIA GeForce GTX 1070
    Driver version: 21.21.13.7570
    Screen Resolution: 1920x1200x32bit @ 59Hz
  1. RFO Benchmark v3
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: August 28th, 2017, 01:18 AM
  2. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  3. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
  4. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 02:08 PM
