Page 5 of 5 FirstFirst 12345
Results 41 to 48 of 48
Like Tree1Likes
Thread: RFO Benchmark v3 2017 results
  1.    #41
    New Member bmarrow's Avatar
    April 27, 2017
    2
    03:03 PM
    Quote Originally Posted by bmarrow View Post
    RVT 2017 - Standard set - 2017.04.27 @ 10.35.27 on FRANK
    RFO Benchmark v3.0 (build 17.10.2016)
    RevitForum.org
    All times are in seconds, lower is better.
    Run on Autodesk Revit 2017 SP2
    __________________________________________________ _______________
    Update
    8.02 update previous version file
    Model creation benchmark
    2.37 opening and loading the custom template
    7.71 creating the floors levels and grids
    13.26 creating a group of walls and doors
    25.10 modifying the group by adding a curtain wall
    7.91 creating the exterior curtain wall
    5.55 creating the sections
    2.79 changing the curtain wall panel type
    6.50 creating area plans
    0.98 creating and applying view template
    72.17 TOTAL
    Export benchmark
    42.45 export all views as PNGs at 300 dpi
    34.26 export all views as DWFs
    63.41 export all views as DWGs
    39.80 print all views as vector *
    62.02 print all views as raster *
    Notes:
    * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
    54.18 render
    Graphics benchmark
    3.28 refresh Hidden Line view x12
    3.31 refresh Consistent Colors view x12
    4.08 refresh Realistic view x12
    1.22 rotate view x1
    Notes:
    Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    To meaningfully compare graphics cards, test all cards in the same machine
    and use the 'Graphics - expanded' benchmark.
    Raw Data
    8.012 8.109 7.934 update previous version file
    2.356 2.320 2.438 opening and loading the custom template
    7.539 7.758 7.824 creating the floors levels and grids
    13.203 13.340 13.234 creating a group of walls and doors
    25.168 25.113 25.023 modifying the group by adding a curtain wall
    8.312 7.699 7.707 creating the exterior curtain wall
    5.656 5.539 5.465 creating the sections
    2.797 2.793 2.773 changing the curtain wall panel type
    6.617 6.477 6.402 creating area plans
    0.930 1.016 1.000 creating and applying view template
    41.984 43.223 42.129 export all views as PNGs at 300 dpi
    34.262 34.582 33.949 export all views as DWFs
    63.684 63.230 63.324 export all views as DWGs
    39.887 39.848 39.664 print all views as vector
    62.223 62.008 61.828 print all views as raster
    54.394 54.039 54.094 render
    3.246 3.320 3.262 refresh Hidden Line view x12
    3.379 3.273 3.266 refresh Consistent Colors view x12
    4.082 4.070 4.086 refresh Realistic view x12
    1.301 1.180 1.191 rotate view x1
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz (O.C. 5.0)
    Max Clock Speed: 4.2Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 32GB @ 2400 2400 2400 2400Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: NVMe Samsung SSD 960
    Graphics Card: NVIDIA GeForce GTX 970
    Graphics RAM: 3.9990234375GB
    Driver version: 21.21.13.7653
    Screen Resolution: 1920x 1080x32bit @ 60Hz
    Looks like the lesson here is: use a 7700k.
    I'm going to run this same system with a Quadro M4000. I'm not anticipating much difference.
    Update:
    I reran the test on the same system with a Quadro M4000 card. Remarkably, every test was slightly improved EXCEPT the graphics benchmark. Also, it is registering the card as only having ~4GB of GDDR instead of 8, so I'll need to look into that.
    RVT 2017 - Standard set - 2017.04.27 @ 14.15.22 on FRANK
    RevitForum.org
    Update
    8.25 update previous version file
    2.33 opening and loading the custom template
    7.52 creating the floors levels and grids
    13.05 creating a group of walls and doors
    24.66 modifying the group by adding a curtain wall
    7.38 creating the exterior curtain wall
    5.25 creating the sections
    2.62 changing the curtain wall panel type
    6.16 creating area plans
    0.90 creating and applying view template
    69.87 TOTAL
    Export benchmark
    41.71 export all views as PNGs at 300 dpi
    33.84 export all views as DWFs
    63.18 export all views as DWGs
    39.69 print all views as vector *
    57.44 print all views as raster *
    Notes:
    Render benchmark
    54.02 render
    Graphics benchmark
    3.22 refresh Hidden Line view x12
    3.23 refresh Consistent Colors view x12
    4.02 refresh Realistic view x12
    1.21 rotate view x1
    Notes:
    Raw Data
    8.836 7.949 7.957 update previous version file
    2.430 2.320 2.242 opening and loading the custom template
    7.477 7.621 7.449 creating the floors levels and grids
    13.137 12.992 13.016 creating a group of walls and doors
    24.637 24.637 24.707 modifying the group by adding a curtain wall
    7.410 7.387 7.336 creating the exterior curtain wall
    5.270 5.281 5.191 creating the sections
    2.629 2.625 2.606 changing the curtain wall panel type
    6.207 6.160 6.121 creating area plans
    0.883 0.914 0.914 creating and applying view template
    41.730 41.691 41.707 export all views as PNGs at 300 dpi
    33.856 33.770 33.894 export all views as DWFs
    62.828 64.211 62.492 export all views as DWGs
    39.789 39.648 39.625 print all views as vector
    56.859 58.574 56.891 print all views as raster
    54.203 53.758 54.098 render
    3.199 3.219 3.238 refresh Hidden Line view x12
    3.215 3.250 3.230 refresh Consistent Colors view x12
    4.016 4.035 4.023 refresh Realistic view x12
    1.164 1.262 1.215 rotate view x1
    TEST CONDITIONS:
    CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz (5.0 O.C)
    Graphics Card: NVIDIA Quadro M4000
    Driver version: 21.21.13.7711
    Screen Resolution: 1920x1080x32bit @ 60Hz
  2.    #42
    Member remiscs's Avatar
    May 18, 2015
    Huntington Beach, CA
    100
    08:03 AM
    Update:
    ***Snip***
    If not mistaken is not the M4000 based off the GTX970 core but at a lower clock speed? I believe that was the case and the m5000 was the gtx980 and m6000/titan x. It has been a while so I am a bit rusty on that. If I am right the reason the GPU section was slower would likely just be the clock speed is lower on the M4000. Also, maybe revit read the RAM incorrectly because of the old geforce drivers still being installed?
    I love using DDU (display driver uninstaller) any time a GPU swap from different families is made or when there could be a GPU related issue. It wipes the drivers CLEAN as if they were never installed. I dont think it works on Quadro drivers or Firepro/Radeon Pro but at least for normal Geforce and Radeon drivers it works perfectly.
    Link:
    Display Driver Uninstaller Download version 17.0.6.4
  3.    #43
    May 2, 2017
    2
    09:03 AM
    Quote Originally Posted by Smallaha View Post
    TEST CONDITIONS:
    OS: Microsoft Windows 7 Professional 64-bit
    Max Clock Speed: 4.201Ghz
    Total Physical Memory: 32GB @ Mhz
    Drive Model: Samsung SSD 850 EVO 500GB ATA Device
    Graphics Card: NVIDIA GeForce GTX 1060 6GB
    Driver version: 21.21.13.7892
    Smallaha,
    I am interested in a bit more info on your system specs as you have the best scores of the thread I've seen so far. Not seeing the Mhz on your ram what speeds are you running and are you running the i7-7700k stock or overclocked at all? Any info would be appreciated we are getting ready to order the parts for and build 4 new machines in the next week or so based on the i7-7700k.
  4.    #44
    May 18, 2015
    100
    08:03 AM
    Quote Originally Posted by EthanES2 View Post
    Smallaha,
    I too wish revit reported the actual speed. I have found many samples that have come through here to hit 5ghz BUT to really do it 24/7 they need to have the IHS removed to replace the thermal compound intel uses (known as delidding). I actually perform this service and have videos on it but you can also find a lot of information on it at youtube if you are curious. 15-24c temp drops are about what can be expected.
    Since I only have a demo of Revit I cant get accurate scores on my 5ghz 7700k with revit 2017.
  5.    #45
    May 11, 2017
    1
    03:03 PM
    I try to run the benchmark on Revit 2017 (Student) and i get ''no response" every time i starts a new task. System is a Ryzen 1600,16GB 2933 DDR4 and Radeon R9 290X.
    Is that normal or i need to set up something?
  6.    #46
    September 12, 2011
    2
    10:03 PM
    My Ryzen 1700X.
    RVT 2017 - Standard set - 2017.05.19 @ 22.19.41 on DESKTOP-N2C4KJC
    RevitForum.org
    Update
    13.21 update previous version file
    3.42 opening and loading the custom template
    11.43 creating the floors levels and grids
    23.89 creating a group of walls and doors
    43.79 modifying the group by adding a curtain wall
    12.88 creating the exterior curtain wall
    9.16 creating the sections
    4.50 changing the curtain wall panel type
    10.48 creating area plans
    1.50 creating and applying view template
    121.05 TOTAL
    Export benchmark
    74.41 export all views as PNGs at 300 dpi
    108.16 export all views as DWFs
    177.77 export all views as DWGs
    90.48 print all views as vector *
    112.62 print all views as raster *
    Notes:
    Render benchmark
    32.55 render
    Graphics benchmark
    5.26 refresh Hidden Line view x12
    5.27 refresh Consistent Colors view x12
    6.50 refresh Realistic view x12
    2.14 rotate view x1
    Notes:
    Raw Data
    14.062 12.766 12.797 update previous version file
    3.422 3.398 3.430 opening and loading the custom template
    11.578 11.391 11.320 creating the floors levels and grids
    24.555 23.391 23.734 creating a group of walls and doors
    44.070 43.688 43.602 modifying the group by adding a curtain wall
    13.047 12.844 12.758 creating the exterior curtain wall
    9.492 8.812 9.180 creating the sections
    4.523 4.523 4.461 changing the curtain wall panel type
    10.820 10.688 9.930 creating area plans
    1.531 1.484 1.484 creating and applying view template
    74.234 74.273 74.734 export all views as PNGs at 300 dpi
    108.227 108.242 108.016 export all views as DWFs
    179.312 176.805 177.188 export all views as DWGs
    91.133 90.086 90.227 print all views as vector
    113.719 111.281 112.867 print all views as raster
    51.992 45.648 render
    5.273 5.219 5.273 refresh Hidden Line view x12
    5.320 5.266 5.219 refresh Consistent Colors view x12
    6.570 6.469 6.453 refresh Realistic view x12
    2.172 2.109 2.148 rotate view x1
    TEST CONDITIONS:
    Mfr: Micro-Star International Co., Ltd
    Model: MS-7A32
    CPU: AMD Ryzen 7 1700X Eight-Core Processor
    Max Clock Speed: 3.4Ghz
    Number of Processors: 8
    Number of Logical Processors: 16
    Total Physical Memory: 16GB @ 3200 3200Mhz
    Drive Model: SAMSUNG MZVPV512HDGL-000H1
    Graphics Card: NVIDIA GeForce GTX 1050 Ti
    Driver version: 22.21.13.8189
    Screen Resolution: 2560x1080x32bit @ 59Hz
  7.    #47
    December 16, 2013
    3
    11:03 AM
    I scrubbed through all results posted here thus far and do not see anyone has tested resolution set higher than 2560x1440. All MS Surface hardware default resolutions are higher than this. I will dial down my display settings and try running RFO Benchmark2017 again but in mean time I thought I would post here to inquire to those that are familiar w/inner workings of this script if perhaps there might be a reason I can't get benchmark script to run to completion because of resolution size? I am trying to eliminate variables.
  8.    #48
    May 18, 2015
    100
    08:03 AM
    Quote Originally Posted by mwaychoff View Post
    That sounds like it could be a possibility, good luck. I ran it once on my 4k monitor but I was on a trial version of 2017 so kept getting promts to accept the trial terms mid way. It did complete though but that is also a different variable. Hope you get it to work.
  1. RFO Benchmark v3
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: Today, 02:44 PM
  2. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
  3. RFO Benchmark v3 2015 results
    Last Post: October 18th, 2016, 07:29 PM
  4. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 02:08 PM
