Donate Now Goal amount for this year: 3000 USD, Received: 2285 USD (76%)
Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 66
Like Tree5Likes
Thread: RFO Benchmark v3 2017 results
  1. #11
    Member BD Mackey's Avatar
    November 1, 2013
    466
    07:48 PM
    My main machine Sager Workstation class LapTop
    RVT 2017 - Standard set - 2016.12.05 @ 18.56.30 on BDMACKEYL2
    RFO Benchmark v3.0 (build 17.10.2016)
    RevitForum.org
    All times are in seconds, lower is better.
    Run on Autodesk Revit 2017.1.1
    __________________________________________________ _______________
    Update
    13.31 update previous version file
    Model creation benchmark
    3.10 opening and loading the custom template
    10.93 creating the floors levels and grids
    21.04 creating a group of walls and doors
    38.10 modifying the group by adding a curtain wall
    12.19 creating the exterior curtain wall
    9.01 creating the sections
    4.35 changing the curtain wall panel type
    10.30 creating area plans
    1.43 creating and applying view template
    110.45 TOTAL
    Export benchmark
    67.99 export all views as PNGs at 300 dpi
    53.20 export all views as DWFs
    96.28 export all views as DWGs
    61.76 print all views as vector *
    108.85 print all views as raster *
    Notes:
    * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
    95.33 render
    Graphics benchmark
    5.04 refresh Hidden Line view x12
    5.08 refresh Consistent Colors view x12
    6.11 refresh Realistic view x12
    1.92 rotate view x1
    Notes:
    Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    To meaningfully compare graphics cards, test all cards in the same machine
    and use the 'Graphics - expanded' benchmark.
    Raw Data
    15.398 12.266 12.273 update previous version file
    3.094 3.109 3.102 opening and loading the custom template
    10.961 10.891 10.930 creating the floors levels and grids
    21.070 20.961 21.102 creating a group of walls and doors
    37.938 38.086 38.281 modifying the group by adding a curtain wall
    12.125 12.273 12.164 creating the exterior curtain wall
    9.125 8.914 8.984 creating the sections
    4.555 4.328 4.180 changing the curtain wall panel type
    10.125 10.344 10.422 creating area plans
    1.469 1.438 1.383 creating and applying view template
    67.414 67.406 69.164 export all views as PNGs at 300 dpi
    53.219 52.609 53.758 export all views as DWFs
    96.523 95.500 96.828 export all views as DWGs
    61.742 61.750 61.773 print all views as vector
    109.078 108.195 109.281 print all views as raster
    90.508 90.039 105.445 render
    4.992 5.023 5.102 refresh Hidden Line view x12
    5.141 5.047 5.062 refresh Consistent Colors view x12
    6.102 6.133 6.109 refresh Realistic view x12
    1.914 1.945 1.906 rotate view x1
    TEST CONDITIONS:
    Mfr: Notebook
    Model: P377SM-A
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-4810MQ CPU @ 2.80GHz
    Max Clock Speed: 2.801Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 32GB @ 1600 1600 1600 1600Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 840 EVO 1TB mSATA
    Graphics Card: NVIDIA GeForce GTX 980M
    Graphics RAM: 3.9990234375GB
    Driver version: 21.21.13.6909
    Screen Resolution: 1920x1080x32bit @ 60Hz
  2. #12
    Member mjajansen's Avatar
    December 26, 2011
    75
    01:48 AM
    I ran the standard test last night.
    RVT 2017 - Standard set - 2016.12.07 @ 21.58.16 on DESKTOP-4JK0PAK
    RevitForum.org
    Run on Autodesk Revit 2017 FCS
    Update
    9.72 update previous version file
    2.80 opening and loading the custom template
    9.85 creating the floors levels and grids
    16.88 creating a group of walls and doors
    30.99 modifying the group by adding a curtain wall
    9.74 creating the exterior curtain wall
    7.56 creating the sections
    3.37 changing the curtain wall panel type
    8.44 creating area plans
    1.13 creating and applying view template
    90.76 TOTAL
    Export benchmark
    53.71 export all views as PNGs at 300 dpi
    75.90 export all views as DWFs
    205.12 export all views as DWGs
    61.81 print all views as vector *
    84.36 print all views as raster *
    Notes:
    Render benchmark
    69.80 render
    Graphics benchmark
    4.28 refresh Hidden Line view x12
    4.32 refresh Consistent Colors view x12
    5.28 refresh Realistic view x12
    1.69 rotate view x1
    Notes:
    Raw Data
    9.797 9.664 9.688 update previous version file
    2.820 2.820 2.773 opening and loading the custom template
    10.133 10.188 9.242 creating the floors levels and grids
    16.578 17.250 16.812 creating a group of walls and doors
    30.672 31.266 31.039 modifying the group by adding a curtain wall
    9.633 9.820 9.773 creating the exterior curtain wall
    7.461 7.688 7.531 creating the sections
    3.344 3.414 3.352 changing the curtain wall panel type
    8.328 8.477 8.508 creating area plans
    1.109 1.133 1.141 creating and applying view template
    53.633 53.734 53.773 export all views as PNGs at 300 dpi
    75.938 75.844 75.930 export all views as DWFs
    203.391 205.977 206.000 export all views as DWGs
    61.969 61.672 61.797 print all views as vector
    84.727 84.266 84.086 print all views as raster
    66.703 76.203 66.500 render
    4.281 4.273 4.273 refresh Hidden Line view x12
    4.305 4.320 4.328 refresh Consistent Colors view x12
    5.305 5.258 5.273 refresh Realistic view x12
    1.664 1.719 1.688 rotate view x1
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
    Max Clock Speed: 4.001Ghz
    Total Physical Memory: 32GB @ 2133 2133 2133 2133Mhz
    Drive Model: Crucial_CT525MX300SSD1
    Graphics Card: NVIDIA GeForce GTX 1060 6GB
    Driver version: 21.21.13.7609
    Screen Resolution: 2560x1440x32bit @ 59Hz
  3. #13
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    295
    06:48 PM
    RVT 2017 - Standard set - 2016.12.19 @ 11.41.02 on SEA-L17-D6######
    RevitForum.org
    Run on Autodesk Revit 2017 SP2
    Update
    11.07 update previous version file
    3.12 opening and loading the custom template
    10.65 creating the floors levels and grids
    20.85 creating a group of walls and doors
    38.94 modifying the group by adding a curtain wall
    12.55 creating the exterior curtain wall
    9.39 creating the sections
    4.26 changing the curtain wall panel type
    10.18 creating area plans
    1.42 creating and applying view template
    111.36 TOTAL
    Export benchmark
    69.59 export all views as PNGs at 300 dpi
    92.77 export all views as DWFs
    150.43 export all views as DWGs
    72.95 print all views as vector *
    99.43 print all views as raster *
    Notes:
    Render benchmark
    86.26 render
    Graphics benchmark
    5.16 refresh Hidden Line view x12
    5.21 refresh Consistent Colors view x12
    6.42 refresh Realistic view x12
    3.19 rotate view x1
    Notes:
    Raw Data
    11.547 10.824 10.824 update previous version file
    3.082 3.082 3.199 opening and loading the custom template
    10.793 10.453 10.715 creating the floors levels and grids
    22.004 20.215 20.344 creating a group of walls and doors
    40.723 38.172 37.914 modifying the group by adding a curtain wall
    13.562 11.848 12.230 creating the exterior curtain wall
    9.938 9.098 9.137 creating the sections
    4.527 4.074 4.180 changing the curtain wall panel type
    10.387 10.305 9.859 creating area plans
    1.438 1.414 1.398 creating and applying view template
    69.469 68.020 71.285 export all views as PNGs at 300 dpi
    95.090 91.723 91.492 export all views as DWFs
    150.008 151.891 149.379 export all views as DWGs
    73.168 72.879 72.797 print all views as vector
    101.852 97.961 98.465 print all views as raster
    82.262 81.773 94.742 render
    5.195 5.184 5.102 refresh Hidden Line view x12
    5.180 5.285 5.176 refresh Consistent Colors view x12
    6.410 6.492 6.371 refresh Realistic view x12
    3.125 3.117 3.340 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision 7510
    OS: Microsoft Windows 7 Enterprise 64-bit
    CPU: Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz
    Max Clock Speed: 2.701Ghz
    Total Physical Memory: 32GB @ Mhz
    Drive Model: LITEON LCH-512V2S-11 2. SCSI Disk Device
    Graphics Card: NVIDIA Quadro M2000M
    Driver version: 10.18.13.5445
    - - - Updated - - -
    RevitForum.org
    Update
    111.36 TOTAL
    Export benchmark
    Notes:
    Render benchmark
    86.26 render
    Graphics benchmark
    3.19 rotate view x1
    Notes:
    Raw Data
    TEST CONDITIONS:
    Mfr: Dell Inc.
  4. #14
    8,825
    08:48 PM
    Its interesting to see how much the resolution affects the test, Markus. You and i have virtually identical machines (as far as the test guys. Slightly different processor, and slightly different RAM config). Mine ran 20 seconds slower, but i was at a higher resolution:
    RVT 2017 - Standard set - 2016.11.19 @ 10.38.00 on PRLX751001
    RevitForum.org
    Update
    9.30 update previous version file
    3.87 opening and loading the custom template
    14.80 creating the floors levels and grids
    24.96 creating a group of walls and doors
    43.41 modifying the group by adding a curtain wall
    14.15 creating the exterior curtain wall
    12.23 creating the sections
    4.93 changing the curtain wall panel type
    11.78 creating area plans
    1.85 creating and applying view template
    131.98 TOTAL
    Export benchmark
    77.95 export all views as PNGs at 300 dpi
    59.12 export all views as DWFs
    128.50 export all views as DWGs
    68.90 print all views as vector *
    108.76 print all views as raster *
    Notes:
    Render benchmark
    92.65 render
    Graphics benchmark
    5.51 refresh Hidden Line view x12
    5.54 refresh Consistent Colors view x12
    6.76 refresh Realistic view x12
    4.62 rotate view x1
    Notes:
    Raw Data
    14.590 13.316 update previous version file
    3.863 3.926 3.832 opening and loading the custom template
    13.949 15.910 14.531 creating the floors levels and grids
    23.691 26.902 24.277 creating a group of walls and doors
    43.559 42.863 43.805 modifying the group by adding a curtain wall
    13.555 14.309 14.578 creating the exterior curtain wall
    12.625 11.066 12.988 creating the sections
    4.762 5.000 5.031 changing the curtain wall panel type
    11.594 11.934 11.812 creating area plans
    1.863 1.828 1.856 creating and applying view template
    78.062 77.789 78.012 export all views as PNGs at 300 dpi
    59.574 58.738 59.059 export all views as DWFs
    129.469 127.867 128.168 export all views as DWGs
    68.438 68.832 69.430 print all views as vector
    106.809 107.426 112.055 print all views as raster
    84.207 97.113 96.621 render
    5.457 5.531 5.543 refresh Hidden Line view x12
    5.520 5.520 5.586 refresh Consistent Colors view x12
    6.742 6.730 6.816 refresh Realistic view x12
    4.594 4.637 4.633 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    CPU: Intel(R) Core(TM) i7-6920HQ CPU @ 2.90GHz
    Max Clock Speed: 2.904Ghz
    Total Physical Memory: 64GB @ 2133 2133 2133 2133Mhz
    Drive Type: Network Drive
    Drive Model: Not Available
    Graphics Card: Intel(R) HD Graphics 530
    Graphics RAM: 1GB
    Driver version: 20.19.15.4531
    Screen Resolution: 2560 2560x1440 1440x32bit @ 59 59Hz
  5. #15
    April 19, 2015
    2
    01:48 AM
    My test RVT 2017 - Standard set - 2016.12.24 @ 12.48.58 on DESKTOP-E8OGQFU RFO Benchmark v3.0 (build 17.10.2016) RevitForum.org All times are in seconds, lower is better. Run on Autodesk Revit 2017 FCS __________________________________________________ _______________ Update 15.25 update previous version file __________________________________________________ _______________ Model creation benchmark 3.52 opening and loading the custom template 12.89 creating the floors levels and grids 27.71 creating a group of walls and doors 53.40 modifying the group by adding a curtain wall 16.31 creating the exterior curtain wall 10.58 creating the sections 5.85 changing the curtain wall panel type 12.34 creating area plans 1.91 creating and applying view template 144.51 TOTAL __________________________________________________ _______________ Export benchmark 73.32 export all views as PNGs at 300 dpi 130.27 export all views as DWFs 220.42 export all views as DWGs 102.47 print all views as vector * 117.76 print all views as raster * Notes: * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed. __________________________________________________ _______________ Render benchmark 141.45 render __________________________________________________ _______________ Graphics benchmark 8.36 refresh Hidden Line view x12 8.49 refresh Consistent Colors view x12 10.19 refresh Realistic view x12 2.66 rotate view x1 Notes: Graphics benchmark measures the entire graphics stack, which includes CPU and memory. To meaningfully compare graphics cards, test all cards in the same machine and use the 'Graphics - expanded' benchmark. Raw Data 16.180 14.770 14.789 update previous version file 3.492 3.535 3.535 opening and loading the custom template 13.051 12.891 12.742 creating the floors levels and grids 27.719 27.594 27.809 creating a group of walls and doors 53.324 53.453 53.438 modifying the group by adding a curtain wall 16.234 16.426 16.277 creating the exterior curtain wall 10.438 10.734 10.562 creating the sections 5.754 5.949 5.852 changing the curtain wall panel type 12.531 12.266 12.219 creating area plans 1.789 1.984 1.945 creating and applying view template 73.184 73.356 73.406 export all views as PNGs at 300 dpi 129.969 131.199 129.641 export all views as DWFs 223.414 219.781 218.055 export all views as DWGs 102.051 103.125 102.234 print all views as vector 117.660 117.953 117.652 print all views as raster 126.613 166.797 130.926 render 8.203 8.129 8.738 refresh Hidden Line view x12 8.344 8.223 8.918 refresh Consistent Colors view x12 10.055 9.926 10.586 refresh Realistic view x12 2.637 2.613 2.742 rotate view x1 TEST CONDITIONS: __________________________________________________ _____ Mfr: To Be Filled By O.E.M. Model: To Be Filled By O.E.M. OS: Microsoft Windows 10 Pro64-bit __________________________________________________ _____ CPU: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz Max Clock Speed: 3.201Ghz Number of Processors: 4 Number of Logical Processors: 4 Total Physical Memory: 16GB @ 1600 1600 1600Mhz __________________________________________________ _____ Drive Type: local Disk (NTFS) Drive Model: Samsung SSD 840 EVO 120GB __________________________________________________ _____ Graphics Card: AMD Radeon HD 7800 Series Graphics RAM: 2GB Driver version: 21.19.137.1 __________________________________________________ _____ Screen Resolution: 1920x1080x32bit @ 60Hz
  6. #16
    July 27, 2012
    295
    06:48 PM
    RVT 2017 - Standard set - 2016.12.28 @ 06.44.12 on SEA-L16-HGxxxxx
    RevitForum.org
    Update
    13.41 update previous version file
    4.40 opening and loading the custom template
    11.41 creating the floors levels and grids
    19.49 creating a group of walls and doors
    36.40 modifying the group by adding a curtain wall
    11.56 creating the exterior curtain wall
    8.03 creating the sections
    4.50 changing the curtain wall panel type
    9.34 creating area plans
    1.38 creating and applying view template
    106.51 TOTAL
    Export benchmark
    59.17 export all views as PNGs at 300 dpi
    48.64 export all views as DWFs
    89.99 export all views as DWGs
    54.91 print all views as vector *
    93.73 print all views as raster *
    Notes:
    Render benchmark
    95.64 render
    Graphics benchmark
    5.46 refresh Hidden Line view x12
    5.60 refresh Consistent Colors view x12
    8.49 refresh Realistic view x12
    1.97 rotate view x1
    Notes:
    Raw Data
    15.250 12.531 12.447 update previous version file
    4.381 4.467 4.361 opening and loading the custom template
    11.561 11.029 11.635 creating the floors levels and grids
    19.541 19.496 19.441 creating a group of walls and doors
    36.234 36.644 36.320 modifying the group by adding a curtain wall
    11.588 11.631 11.455 creating the exterior curtain wall
    8.148 7.922 8.016 creating the sections
    4.547 4.365 4.590 changing the curtain wall panel type
    9.338 9.406 9.272 creating area plans
    1.348 1.400 1.404 creating and applying view template
    58.834 59.789 58.883 export all views as PNGs at 300 dpi
    48.840 48.496 48.582 export all views as DWFs
    90.604 89.758 89.594 export all views as DWGs
    55.012 55.230 54.480 print all views as vector
    93.881 93.525 93.770 print all views as raster
    93.109 92.975 100.826 render
    5.488 5.510 5.371 refresh Hidden Line view x12
    5.410 6.002 5.389 refresh Consistent Colors view x12
    8.082 8.135 9.260 refresh Realistic view x12
    1.940 2.008 1.957 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision M4800
    Drive Model: SK hynix SH920 2.5 SCSI Disk Device
    Graphics Card: NVIDIA Quadro K2100M
    Graphics RAM: 2GB
    Driver version: 21.21.13.7563
    Screen Resolution: 1920x1200x32bit @ 59Hz
  7. #17
    July 27, 2012
    295
    06:48 PM
    RVT 2017 - Standard set - 2016.12.28 @ 13.10.42 on SEA-D16-JWxxxxx
    RevitForum.org
    Update
    12.62 update previous version file
    3.27 opening and loading the custom template
    12.60 creating the floors levels and grids
    22.95 creating a group of walls and doors
    44.45 modifying the group by adding a curtain wall
    14.14 creating the exterior curtain wall
    9.84 creating the sections
    4.57 changing the curtain wall panel type
    11.43 creating area plans
    1.68 creating and applying view template
    124.93 TOTAL
    Export benchmark
    72.80 export all views as PNGs at 300 dpi
    56.37 export all views as DWFs
    116.88 export all views as DWGs
    69.27 print all views as vector *
    109.13 print all views as raster *
    Notes:
    Render benchmark
    65.98 render
    Graphics benchmark
    7.60 refresh Hidden Line view x12
    7.28 refresh Consistent Colors view x12
    8.93 refresh Realistic view x12
    2.59 rotate view x1
    Notes:
    Raw Data
    12.773 12.391 12.684 update previous version file
    3.117 3.199 3.496 opening and loading the custom template
    12.332 11.500 13.973 creating the floors levels and grids
    20.336 22.992 25.508 creating a group of walls and doors
    38.586 48.164 46.602 modifying the group by adding a curtain wall
    13.453 14.644 14.324 creating the exterior curtain wall
    9.078 9.848 10.594 creating the sections
    4.250 4.574 4.879 changing the curtain wall panel type
    11.242 11.281 11.770 creating area plans
    1.652 1.688 1.699 creating and applying view template
    72.172 74.059 72.156 export all views as PNGs at 300 dpi
    54.891 57.215 56.992 export all views as DWFs
    120.844 116.281 113.516 export all views as DWGs
    70.711 71.746 65.348 print all views as vector
    114.113 112.090 101.184 print all views as raster
    66.938 65.812 65.184 render
    7.809 7.625 7.367 refresh Hidden Line view x12
    7.629 7.000 7.219 refresh Consistent Colors view x12
    9.375 8.805 8.621 refresh Realistic view x12
    2.594 2.594 2.582 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision Tower 5810
    CPU: Intel(R) Xeon(R) CPU E5-1650 v3 @ 3.50GHz
    Max Clock Speed: 3.501Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 96GB @ Mhz
    Drive Model: Crucial_CT500MX200SSD1 ATA Device
    Graphics Card: NVIDIA Quadro K2200
    Driver version: 10.18.13.5891
    Screen Resolution: 1600x1200x32bit @ 60Hz
  8. #18
    April 13, 2016
    3
    01:48 AM
    RVT 2017 - Standard set - 2017.01.13 @ 09.16.05 on STH15004
    RevitForum.org
    Update
    17.55 update previous version file
    4.60 opening and loading the custom template
    18.29 creating the floors levels and grids
    31.68 creating a group of walls and doors
    53.62 modifying the group by adding a curtain wall
    17.68 creating the exterior curtain wall
    17.30 creating the sections
    6.10 changing the curtain wall panel type
    15.49 creating area plans
    2.54 creating and applying view template
    167.30 TOTAL
    Export benchmark
    94.84 export all views as PNGs at 300 dpi
    64.76 export all views as DWFs
    130.76 export all views as DWGs
    61.92 print all views as vector *
    70.18 print all views as raster *
    Notes:
    Render benchmark
    49.57 render
    Graphics benchmark
    6.75 refresh Hidden Line view x12
    6.66 refresh Consistent Colors view x12
    8.33 refresh Realistic view x12
    5.87 rotate view x1
    Notes:
    Raw Data
    17.625 17.480 17.555 update previous version file
    4.641 4.613 4.547 opening and loading the custom template
    17.902 18.180 18.797 creating the floors levels and grids
    31.043 32.727 31.285 creating a group of walls and doors
    54.230 52.711 53.918 modifying the group by adding a curtain wall
    17.879 17.508 17.648 creating the exterior curtain wall
    15.734 17.606 18.547 creating the sections
    5.840 5.691 6.754 changing the curtain wall panel type
    15.203 15.594 15.668 creating area plans
    2.453 2.551 2.629 creating and applying view template
    80.559 100.910 103.043 export all views as PNGs at 300 dpi
    63.461 62.992 67.824 export all views as DWFs
    129.918 131.379 130.980 export all views as DWGs
    62.090 62.594 61.090 print all views as vector
    69.617 69.867 71.055 print all views as raster
    50.215 49.961 48.539 render
    6.629 6.691 6.926 refresh Hidden Line view x12
    6.414 6.730 6.840 refresh Consistent Colors view x12
    8.547 8.133 8.309 refresh Realistic view x12
    5.961 6.180 5.480 rotate view x1
    TEST CONDITIONS:
    Mfr: Hewlett-Packard
    Model: HP Z840 Workstation
    OS: Microsoft Windows 10 Enterprise64 64-bit
    CPU: Intel(R) Xeon(R) CPU E5-2620 v3 @ 2.40GHz Intel(R) Xeon(R) CPU E5-2620 v3 @ 2.40GHz
    Max Clock Speed: Ghz
    Number of Processors: 6 6
    Number of Logical Processors: 12 12
    Total Physical Memory: 128GB @ 2133 2133 2133 2133 2133 2133 2133 2133Mhz
    Drive Model: ATA Samsung SSD 850 SCSI Disk Device
    Graphics Card: @oem266.inf,%dwmirrordrv% 64-bit;DameWare Development Mirror Driver 64-bit
    Graphics RAM: 0GB
    Driver version: 1.1.0.0
    Graphics Card: HP Remote Graphics Driver
    Graphics RAM: 0GB
    Driver version: 7.0.1.4255
    Graphics Card: NVIDIA Quadro 2000
    Graphics RAM: 1GB
    Driver version: 21.21.13.7295
    Screen Resolution: 1280 1280x 1024 1024x32bit @ 60 60Hz
  9. #19
    January 11, 2017
    1
    08:48 PM
    RVT 2017 - Standard set - 2017.01.12 @ 16.33.49 on CLEACAD_7207FZ1
    RevitForum.org
    Run on Autodesk Revit 2017 SP1
    Update
    16.88 update previous version file
    3.58 opening and loading the custom template
    13.27 creating the floors levels and grids
    27.01 creating a group of walls and doors
    50.19 modifying the group by adding a curtain wall
    15.16 creating the exterior curtain wall
    9.74 creating the sections
    5.34 changing the curtain wall panel type
    11.30 creating area plans
    2.60 creating and applying view template
    138.19 TOTAL
    Export benchmark
    98.56 export all views as PNGs at 300 dpi
    116.59 export all views as DWFs
    205.22 export all views as DWGs
    96.67 print all views as vector *
    164.66 print all views as raster *
    Notes:
    Render benchmark
    107.54 render
    Graphics benchmark
    7.67 refresh Hidden Line view x12
    7.71 refresh Consistent Colors view x12
    9.27 refresh Realistic view x12
    2.67 rotate view x1
    Notes:
    Raw Data
    24.234 13.180 13.211 update previous version file
    3.965 3.430 3.336 opening and loading the custom template
    16.328 11.578 11.906 creating the floors levels and grids
    28.578 26.344 26.113 creating a group of walls and doors
    50.406 49.652 50.504 modifying the group by adding a curtain wall
    15.414 15.020 15.039 creating the exterior curtain wall
    9.836 9.617 9.758 creating the sections
    5.492 5.258 5.270 changing the curtain wall panel type
    11.766 11.059 11.086 creating area plans
    1.816 1.609 4.383 creating and applying view template
    73.027 72.863 149.781 export all views as PNGs at 300 dpi
    116.746 116.266 116.758 export all views as DWFs
    208.176 203.785 203.691 export all views as DWGs
    97.398 95.992 96.621 print all views as vector
    164.875 165.242 163.867 print all views as raster
    99.582 112.184 110.859 render
    7.680 7.812 7.504 refresh Hidden Line view x12
    7.656 7.902 7.570 refresh Consistent Colors view x12
    9.191 9.453 9.164 refresh Realistic view x12
    2.906 2.602 2.500 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision T3600
    OS: Microsoft Windows 7 Ultimate 64-bit
    CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
    Max Clock Speed: 3.601Ghz
    Total Physical Memory: 16GB @ Mhz
    Drive Model: DELL PERC H310 SCSI Disk Device
    Graphics Card: NVIDIA Quadro K5000
    Driver version: 21.21.13.7290
  10. #20
    January 12, 2013
    4
    01:48 AM
    RVT 2017 - Standard set - 2017.01.13 @ 20.31.56 on ELITEBOOK-HP
    RevitForum.org
    Run on Autodesk Revit 2017.0.3 Security Fix
    Update
    14.04 update previous version file
    3.65 opening and loading the custom template
    14.87 creating the floors levels and grids
    28.17 creating a group of walls and doors
    49.22 modifying the group by adding a curtain wall
    16.16 creating the exterior curtain wall
    11.50 creating the sections
    5.88 changing the curtain wall panel type
    13.47 creating area plans
    1.76 creating and applying view template
    144.68 TOTAL
    Export benchmark
    91.90 export all views as PNGs at 300 dpi
    138.03 export all views as DWFs
    200.88 export all views as DWGs
    93.05 print all views as vector *
    146.37 print all views as raster *
    Notes:
    Render benchmark
    201.16 render
    Graphics benchmark
    8.24 refresh Hidden Line view x12
    8.23 refresh Consistent Colors view x12
    11.66 refresh Realistic view x12
    4.04 rotate view x1
    Notes:
    Raw Data
    14.219 13.766 14.133 update previous version file
    3.609 3.688 3.664 opening and loading the custom template
    14.820 14.984 14.812 creating the floors levels and grids
    28.398 28.000 28.102 creating a group of walls and doors
    49.289 49.273 49.109 modifying the group by adding a curtain wall
    16.336 16.039 16.094 creating the exterior curtain wall
    11.492 11.586 11.430 creating the sections
    6.023 5.805 5.797 changing the curtain wall panel type
    13.508 13.555 13.344 creating area plans
    1.750 1.805 1.727 creating and applying view template
    92.148 91.758 91.789 export all views as PNGs at 300 dpi
    138.188 137.766 138.125 export all views as DWFs
    202.242 199.344 201.055 export all views as DWGs
    93.219 92.898 93.031 print all views as vector
    145.391 146.359 147.352 print all views as raster
    200.891 201.055 201.531 render
    8.250 8.180 8.281 refresh Hidden Line view x12
    8.281 8.172 8.227 refresh Consistent Colors view x12
    11.727 11.633 11.609 refresh Realistic view x12
    4.047 4.016 4.047 rotate view x1
    TEST CONDITIONS:
    Mfr: HP
    Model: HP EliteBook 840 G3
    OS: Microsoft Windows 7 Professional 64-bit
    CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
    Max Clock Speed: 2.301Ghz
    Number of Processors: 2
    Total Physical Memory: 15GB @ Mhz
    Drive Model: SAMSUNG MZNLN256HCHP-000 SCSI Disk Device
    Graphics Card: Intel(R) HD Graphics 520
    Graphics RAM: 1GB
    Driver version: 20.19.15.4483
  1. RFO Benchmark v3
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: August 28th, 2017, 01:18 AM
  2. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  3. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
  4. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 02:08 PM
