Donate Now Goal amount for this year: 3000 USD, Received: 2285 USD (76%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: RFO Benchmark v3 2016 results
    Rotterdam, South Holland
    2,975
    12:05 AM
    Please post your RFOBenchmark V3 results for the 2016 products here.
    Comments and suggestions should be made in the RFOBenchmark v3 thread. The download is there too.
    Thanks!
    Gordon
    Member kubsix's Avatar
    March 31, 2011
    Quad Cities, Illinois
    254
    05:05 PM
    RVT 2016 - Standard set - 2016.10.25 @ 07.20.38 on JDK0134BOX10
    RFO Benchmark v3.0 (build 17.10.2016)
    RevitForum.org
    All times are in seconds, lower is better.
    Run on Autodesk Revit 2016 FCS
    __________________________________________________ _______________
    Update
    9.85 update previous version file
    Model creation benchmark
    3.10 opening and loading the custom template
    10.66 creating the floors levels and grids
    21.98 creating a group of walls and doors
    40.49 modifying the group by adding a curtain wall
    12.83 creating the exterior curtain wall
    8.78 creating the sections
    4.09 changing the curtain wall panel type
    8.67 creating area plans *
    1.43 creating and applying view template *
    112.03 TOTAL
    Notes:
    * Area and View Template sections are not processed by Revit Structure
    Export benchmark
    64.90 export all views as PNGs at 300 dpi
    109.21 export all views as DWFs
    127.47 export all views as DWGs
    70.79 print all views as vector *
    104.41 print all views as raster *
    Notes:
    * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    ** Revit Structure export times cannot be compared with other verticals
    as view counts are different
    Render benchmark
    202.00 render w/ nvidia mental ray
    Graphics benchmark
    5.95 refresh Hidden Line view x12
    5.75 refresh Consistent Colors view x12
    6.83 refresh Realistic view x12
    2.44 rotate view x1
    Notes:
    Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    To meaningfully compare graphics cards, test all cards in the same machine
    and use the 'Graphics - expanded' benchmark.
    Raw Data
    9.297 9.990 10.268 update previous version file
    2.787 3.244 3.256 opening and loading the custom template
    9.644 11.160 11.176 creating the floors levels and grids
    19.258 24.047 22.648 creating a group of walls and doors
    34.826 42.562 44.074 modifying the group by adding a curtain wall
    11.166 13.635 13.701 creating the exterior curtain wall
    7.453 9.270 9.627 creating the sections
    3.742 4.158 4.357 changing the curtain wall panel type
    7.738 9.070 9.191 creating area plans
    1.213 1.484 1.578 creating and applying view template
    57.113 68.394 69.193 export all views as PNGs at 300 dpi
    93.227 117.637 116.766 export all views as DWFs
    130.010 125.766 126.621 export all views as DWGs
    70.129 72.387 69.848 print all views as vector
    103.875 106.590 102.752 print all views as raster
    231.418 220.545 154.043 render w/ nvidia mental ray
    6.072 5.894 5.871 refresh Hidden Line view x12
    5.633 5.525 6.080 refresh Consistent Colors view x12
    6.818 6.816 6.857 refresh Realistic view x12
    2.404 2.350 2.574 rotate view x1
    TEST CONDITIONS:
    Mfr: BOXX Technologies, Inc
    Model: APEXX 2 2402
    OS: Microsoft Windows 10 Enterprise64-bit
    CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
    Max Clock Speed: 4.001Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 2133 2133Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: SAMSUNG MZHPV256HDGL-00000
    Graphics Card: NVIDIA Quadro M2000
    Graphics RAM: 3.9990234375GB
    Driver version: 21.21.13.7290
    Screen Resolution: 1920x1200x32bit @ 59Hz
    October 15, 2011
    3
    10:05 PM
    RVT 2016 - Standard set - 2016.11.18 @ 19.25.16 on SMOKU
    RevitForum.org
    Update
    8.19 update previous version file
    2.74 opening and loading the custom template
    8.47 creating the floors levels and grids
    16.81 creating a group of walls and doors
    31.49 modifying the group by adding a curtain wall
    9.74 creating the exterior curtain wall
    6.88 creating the sections
    3.28 changing the curtain wall panel type
    7.64 creating area plans *
    1.20 creating and applying view template *
    88.25 TOTAL
    Notes:
    Export benchmark
    57.27 export all views as PNGs at 300 dpi
    79.42 export all views as DWFs
    91.01 export all views as DWGs
    51.22 print all views as vector *
    89.13 print all views as raster *
    Notes:
    Render benchmark
    81.07 render w/ nvidia mental ray
    Graphics benchmark
    4.68 refresh Hidden Line view x12
    4.33 refresh Consistent Colors view x12
    5.27 refresh Realistic view x12
    1.59 rotate view x1
    Notes:
    Raw Data
    8.914 7.883 7.773 update previous version file
    2.742 2.719 2.750 opening and loading the custom template
    8.578 8.422 8.414 creating the floors levels and grids
    16.211 16.992 17.227 creating a group of walls and doors
    31.422 31.148 31.906 modifying the group by adding a curtain wall
    9.805 9.688 9.719 creating the exterior curtain wall
    6.766 6.953 6.922 creating the sections
    3.258 3.266 3.312 changing the curtain wall panel type
    7.664 7.664 7.602 creating area plans
    1.195 1.180 1.219 creating and applying view template
    57.617 57.141 57.062 export all views as PNGs at 300 dpi
    79.594 79.602 79.055 export all views as DWFs
    91.477 90.953 90.586 export all views as DWGs
    51.695 51.031 50.938 print all views as vector
    89.156 89.219 89.016 print all views as raster
    81.367 80.945 80.891 render w/ nvidia mental ray
    4.703 4.648 4.680 refresh Hidden Line view x12
    4.328 4.273 4.391 refresh Consistent Colors view x12
    5.227 5.188 5.406 refresh Realistic view x12
    1.562 1.633 1.578 rotate view x1
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    OS: Microsoft Windows 10 Pro64-bit
    Total Physical Memory: 16GB @ 3000 3000Mhz
    Drive Model: Samsung SSD 850 EVO M.2 250GB
    Graphics Card: NVIDIA GeForce GTX 1070
    Driver version: 21.21.13.7570
    November 7, 2013
    3
    06:05 AM
    RFO Benchmark v2.1 - RVT 2016 'Standard' Test Set 2016.11.02 @ 13.20.57 on NAZRI
    build: 19.01.2016
    RevitForum.org
    Model creation and view export benchmark
    4.22 opening and loading the custom template
    17.32 creating the floors levels and grids
    26.33 creating a group of walls and doors
    44.24 modifying the group by adding a curtain wall
    13.77 creating the exterior curtain wall
    12.01 creating the sections
    4.77 changing the curtain wall panel type
    31.36 export all views as PNGs at 150 dpi
    38.42 export some views as DWGs
    192.44 TOTAL
    Render benchmark
    111.21 render w/ nvidia mental ray
    v1 Graphics benchmark w/ hardware acceleration [1]
    6.34 refresh Hidden Line view x12 - with hardware acceleration
    6.02 refresh Consistent Colors view x12 - with hardware acceleration
    7.62 refresh Realistic view x12 - with hardware acceleration
    3.01 rotate view x1 - with hardware acceleration
    v1 Graphics benchmark w/o hardware acceleration [2]
    80.98 refresh Hidden Line view x12 - without hardware acceleration
    81.73 refresh Consistent Colors view x12 - without hardware acceleration
    83.71 refresh Realistic view x12 - without hardware acceleration
    50.22 rotate view x1 - without hardware acceleration
    [1] Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    and use the 'v2 Graphics - expanded' benchmark.
    [2] For comparison with Hardware Accelerated graphics.
    MACHINE SPEC:
    Mfr: Dell Inc.
    Model: Precision Tower 5810
    OS: Microsoft Windows 7 Professional 64-bit
    CPU: Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz
    Max Clock Speed: 3.501Ghz
    Total Physical Memory: 16GB @ Mhz
    Graphics Card: NVIDIA Quadro K2200
    Driver version: 10.18.13.6191
    Screen Resolution: 1920x1080x32bit @ 60Hz
    Benchmark did run full screen
    Raw Data
    4.926 4.168 3.555 opening and loading the custom template
    21.688 15.367 14.910 creating the floors levels and grids
    27.531 25.953 25.500 creating a group of walls and doors
    45.480 43.539 43.715 modifying the group by adding a curtain wall
    14.109 13.113 14.098 creating the exterior curtain wall
    11.394 12.375 12.246 creating the sections
    4.977 4.664 4.680 changing the curtain wall panel type
    31.598 31.793 30.699 export all views as PNGs at 150 dpi
    43.598 36.008 35.660 export some views as DWGs
    113.859 109.750 110.020 render w/ nvidia mental ray
    6.223 6.398 6.387 refresh Hidden Line view x12 - with hardware acceleration
    5.969 6.137 5.965 refresh Consistent Colors view x12 - with hardware acceleration
    7.527 8.020 7.316 refresh Realistic view x12 - with hardware acceleration
    3.133 3.031 2.863 rotate view x1 - with hardware acceleration
    80.820 81.188 80.938 refresh Hidden Line view x12 - without hardware acceleration
    81.266 81.973 81.938 refresh Consistent Colors view x12 - without hardware acceleration
    83.391 83.730 84.023 refresh Realistic view x12 - without hardware acceleration
    50.406 50.207 50.047 rotate view x1 - without hardware acceleration
    November 7, 2013
    3
    06:05 AM
    RVT 2016 - Standard set - 2016.11.03 @ 14.31.35 on LAPTOP-VMD417AC
    RevitForum.org
    Run on Autodesk Revit 2016 Update3
    Update
    11.54 update previous version file
    3.67 opening and loading the custom template
    12.93 creating the floors levels and grids
    25.65 creating a group of walls and doors
    44.60 modifying the group by adding a curtain wall
    13.89 creating the exterior curtain wall
    10.12 creating the sections
    4.95 changing the curtain wall panel type
    10.15 creating area plans *
    1.69 creating and applying view template *
    127.65 TOTAL
    Notes:
    Export benchmark
    77.20 export all views as PNGs at 300 dpi
    76.12 export all views as DWFs
    123.60 export all views as DWGs
    67.34 print all views as vector *
    131.84 print all views as raster *
    Notes:
    Render benchmark
    266.64 render w/ nvidia mental ray
    Graphics benchmark
    7.42 refresh Hidden Line view x12
    6.90 refresh Consistent Colors view x12
    8.44 refresh Realistic view x12
    4.85 rotate view x1
    Notes:
    Raw Data
    12.738 10.941 10.953 update previous version file
    3.742 3.641 3.625 opening and loading the custom template
    12.977 12.894 12.918 creating the floors levels and grids
    25.871 25.535 25.539 creating a group of walls and doors
    44.715 44.629 44.441 modifying the group by adding a curtain wall
    13.957 13.941 13.785 creating the exterior curtain wall
    10.066 10.043 10.250 creating the sections
    4.934 4.949 4.973 changing the curtain wall panel type
    10.254 10.094 10.106 creating area plans
    1.688 1.691 1.691 creating and applying view template
    77.285 77.082 77.238 export all views as PNGs at 300 dpi
    76.309 75.828 76.234 export all views as DWFs
    122.070 125.676 123.047 export all views as DWGs
    67.660 66.980 67.375 print all views as vector
    135.668 127.871 131.973 print all views as raster
    267.445 266.430 266.055 render w/ nvidia mental ray
    7.543 7.309 7.406 refresh Hidden Line view x12
    7.012 6.867 6.832 refresh Consistent Colors view x12
    8.863 8.250 8.207 refresh Realistic view x12
    4.867 4.848 4.840 rotate view x1
    TEST CONDITIONS:
    Mfr: LENOVO
    Model: 80Q7
    OS: Microsoft Windows 10 Home Single Language64-bit
    CPU: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
    Max Clock Speed: 2.592Ghz
    Number of Processors: 2
    Number of Logical Processors: 4
    Total Physical Memory: 16GB @ 1600 1600Mhz
    Drive Model: ST1000LM024 HN-M101MBB
    Graphics Card: AMD Radeon(TM) R5 M330
    Graphics RAM: 2GB
    Driver version: 16.300.2101.0
    Graphics Card: Intel(R) HD Graphics 520
    Graphics RAM: 1GB
    Driver version: 20.19.15.4474
    Screen Resolution: 1366x 768x32bit @ 60Hz
    - - - Updated - - -
    RVT 2016 - Standard set - 2016.11.03 @ 15.33.43 on DELL-3620-01
    RevitForum.org
    Run on Autodesk Revit 2016 Update7 for R2
    Update
    9.64 update previous version file
    3.38 opening and loading the custom template
    11.23 creating the floors levels and grids
    22.30 creating a group of walls and doors
    40.59 modifying the group by adding a curtain wall
    12.84 creating the exterior curtain wall
    8.83 creating the sections
    4.28 changing the curtain wall panel type
    8.65 creating area plans *
    1.36 creating and applying view template *
    113.46 TOTAL
    Notes:
    Export benchmark
    61.08 export all views as PNGs at 300 dpi
    47.79 export all views as DWFs
    104.56 export all views as DWGs
    57.89 print all views as vector *
    95.65 print all views as raster *
    Notes:
    Render benchmark
    180.83 render w/ nvidia mental ray
    Graphics benchmark
    6.05 refresh Hidden Line view x12
    5.45 refresh Consistent Colors view x12
    6.75 refresh Realistic view x12
    2.74 rotate view x1
    Notes:
    Raw Data
    9.691 9.465 9.766 update previous version file
    3.316 3.352 3.457 opening and loading the custom template
    11.000 11.148 11.555 creating the floors levels and grids
    21.133 21.152 24.602 creating a group of walls and doors
    39.098 39.051 43.621 modifying the group by adding a curtain wall
    12.394 12.461 13.668 creating the exterior curtain wall
    8.656 8.777 9.059 creating the sections
    4.168 4.281 4.379 changing the curtain wall panel type
    8.660 8.402 8.875 creating area plans
    1.328 1.344 1.418 creating and applying view template
    60.984 60.531 61.719 export all views as PNGs at 300 dpi
    46.793 48.535 48.027 export all views as DWFs
    103.148 108.000 102.520 export all views as DWGs
    56.086 61.336 56.254 print all views as vector
    90.316 103.215 93.430 print all views as raster
    174.203 182.809 185.480 render w/ nvidia mental ray
    5.977 6.262 5.910 refresh Hidden Line view x12
    5.367 5.500 5.480 refresh Consistent Colors view x12
    6.719 6.656 6.867 refresh Realistic view x12
    2.637 2.894 2.691 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision Tower 3620
    CPU: Intel(R) Xeon(R) CPU E3-1220 v5 @ 3.00GHz
    Max Clock Speed: 3Ghz
    Total Physical Memory: 32GB @ 2133 2133 2133 2133Mhz
    Drive Model: ST1000DM 003-1SB102 SCSI Disk Device
    Graphics Card: NVIDIA Quadro K620
    Graphics RAM: 2GB
    Driver version: 21.21.13.6909
    - - - Updated - - -
    RVT 2016 - Standard set - 2016.11.04 @ 09.01.02 on DELL5810-01
    RevitForum.org
    Run on Autodesk Revit 2016 Update6 for R2
    Update
    9.49 update previous version file
    3.05 opening and loading the custom template
    10.39 creating the floors levels and grids
    22.03 creating a group of walls and doors
    41.53 modifying the group by adding a curtain wall
    15.78 creating the exterior curtain wall
    8.92 creating the sections
    4.17 changing the curtain wall panel type
    8.78 creating area plans *
    1.38 creating and applying view template *
    116.03 TOTAL
    Notes:
    Export benchmark
    61.56 export all views as PNGs at 300 dpi
    46.72 export all views as DWFs
    97.11 export all views as DWGs
    54.57 print all views as vector *
    92.53 print all views as raster *
    Notes:
    Render benchmark
    104.52 render w/ nvidia mental ray
    Graphics benchmark
    5.91 refresh Hidden Line view x12
    5.60 refresh Consistent Colors view x12
    6.91 refresh Realistic view x12
    2.75 rotate view x1
    Notes:
    Raw Data
    9.180 9.582 9.707 update previous version file
    2.799 3.164 3.180 opening and loading the custom template
    9.340 10.926 10.902 creating the floors levels and grids
    20.334 22.926 22.844 creating a group of walls and doors
    38.639 43.215 42.734 modifying the group by adding a curtain wall
    22.242 12.398 12.688 creating the exterior curtain wall
    8.473 9.098 9.176 creating the sections
    3.945 4.273 4.289 changing the curtain wall panel type
    8.297 8.922 9.109 creating area plans
    1.336 1.461 1.356 creating and applying view template
    59.555 62.719 62.402 export all views as PNGs at 300 dpi
    45.500 46.988 47.684 export all views as DWFs
    94.336 98.227 98.766 export all views as DWGs
    52.770 55.133 55.797 print all views as vector
    90.914 94.516 92.168 print all views as raster
    92.203 96.430 124.918 render w/ nvidia mental ray
    5.648 6.316 5.773 refresh Hidden Line view x12
    5.441 5.672 5.680 refresh Consistent Colors view x12
    6.863 6.992 6.887 refresh Realistic view x12
    2.828 2.715 2.711 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    CPU: Intel(R) Xeon(R) CPU E5-1650 v3 @ 3.50GHz
    Number of Processors: 6
    Number of Logical Processors: 6
    Total Physical Memory: 64GB @ Mhz
    Drive Model: LSI MR9341-8i SCSI Disk Device
    Graphics Card: NVIDIA Quadro K4200
    - - - Updated - - -
    RVT 2016 - Standard set - 2016.11.15 @ 11.09.21 on BIM04-GB03581WS
    RevitForum.org
    Update
    10.62 update previous version file
    3.42 opening and loading the custom template
    11.56 creating the floors levels and grids
    25.64 creating a group of walls and doors
    47.36 modifying the group by adding a curtain wall
    13.50 creating the exterior curtain wall
    9.97 creating the sections
    4.44 changing the curtain wall panel type
    9.04 creating area plans *
    1.44 creating and applying view template *
    126.37 TOTAL
    Notes:
    Export benchmark
    76.58 export all views as PNGs at 300 dpi
    112.65 export all views as DWFs
    129.98 export all views as DWGs
    66.64 print all views as vector *
    115.53 print all views as raster *
    Notes:
    Render benchmark
    184.90 render w/ nvidia mental ray
    Graphics benchmark
    6.54 refresh Hidden Line view x12
    6.34 refresh Consistent Colors view x12
    7.82 refresh Realistic view x12
    2.70 rotate view x1
    Notes:
    Raw Data
    10.422 10.734 10.699 update previous version file
    3.473 3.387 3.402 opening and loading the custom template
    11.441 11.496 11.742 creating the floors levels and grids
    26.125 25.332 25.465 creating a group of walls and doors
    47.074 47.500 47.496 modifying the group by adding a curtain wall
    13.523 13.414 13.562 creating the exterior curtain wall
    10.070 10.031 9.816 creating the sections
    4.719 3.871 4.730 changing the curtain wall panel type
    10.418 6.590 10.102 creating area plans
    1.582 1.160 1.570 creating and applying view template
    76.438 77.023 76.270 export all views as PNGs at 300 dpi
    113.812 111.094 113.055 export all views as DWFs
    129.777 130.098 130.074 export all views as DWGs
    66.367 66.488 67.070 print all views as vector
    114.844 113.609 118.141 print all views as raster
    181.199 182.945 190.559 render w/ nvidia mental ray
    6.520 6.531 6.559 refresh Hidden Line view x12
    6.414 6.332 6.273 refresh Consistent Colors view x12
    7.812 7.824 7.836 refresh Realistic view x12
    2.680 2.781 2.644 rotate view x1
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Max Clock Speed: 3.001Ghz
    Total Physical Memory: 32GB @ Mhz
    Drive Model: LITEON CV3-CE512-11 SAT SCSI Disk Device
    Graphics Card: LANDesk Remote Control Mirror Driver
    Graphics RAM: 0GB
    Driver version: 9.1.0.0
    Screen Resolution: xx32bit @ Hz
    December 12, 2016
    3
    10:05 PM
    RFO Benchmark v2.1 - RVT 2016 'Standard' Test Set 2016.12.13 @ 09.37.32 on A208
    3.79 opening and loading the custom template
    16.44 creating the floors levels and grids
    25.12 creating a group of walls and doors
    42.02 modifying the group by adding a curtain wall
    14.34 creating the exterior curtain wall
    11.92 creating the sections
    4.56 changing the curtain wall panel type
    37.44 export all views as PNGs at 150 dpi
    34.62 export some views as DWGs
    190.25 TOTAL
    Render benchmark
    107.26 render w/ nvidia mental ray
    8.23 refresh Hidden Line view x12 - with hardware acceleration
    7.76 refresh Consistent Colors view x12 - with hardware acceleration
    12.32 refresh Realistic view x12 - with hardware acceleration
    4.89 rotate view x1 - with hardware acceleration
    82.21 refresh Hidden Line view x12 - without hardware acceleration
    83.79 refresh Consistent Colors view x12 - without hardware acceleration
    89.82 refresh Realistic view x12 - without hardware acceleration
    53.70 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    Mfr: Gigabyte Technology Co., Ltd.
    Model: To be filled by O.E.M.
    CPU: Intel(R) Core(TM) i7-6700T CPU @ 2.80GHz
    Max Clock Speed: 2.801Ghz
    Total Physical Memory: 15GB @ 2133 2133Mhz
    Graphics Card: Intel(R) HD Graphics 530
    Graphics RAM: 1GB
    Driver version: 21.20.16.4534
    Benchmark did NOT run full screen
    Results saved to:
    RFO Benchmark v2.1 - RVT 2016 'Standard' Test Set 2016.12.13 @ 09.37.32 on A208.txt
    RFO >
    RVT 2016 - Standard set - 2016.12.13 @ 14.47.25 on A208
    RevitForum.org
    Update
    10.97 update previous version file
    3.73 opening and loading the custom template
    16.38 creating the floors levels and grids
    25.78 creating a group of walls and doors
    42.99 modifying the group by adding a curtain wall
    14.97 creating the exterior curtain wall
    12.64 creating the sections
    4.82 changing the curtain wall panel type
    12.51 creating area plans *
    2.00 creating and applying view template *
    135.82 TOTAL
    Notes:
    Export benchmark
    84.30 export all views as PNGs at 300 dpi
    105.58 export all views as DWFs
    125.51 export all views as DWGs
    0.00 print all views as vector *
    0.00 print all views as raster *
    Notes:
    Render benchmark
    111.83 render w/ nvidia mental ray
    Graphics benchmark
    8.49 refresh Hidden Line view x12
    7.95 refresh Consistent Colors view x12
    12.26 refresh Realistic view x12
    4.23 rotate view x1
    Notes:
    Results saved to: RVT 2016 - Standard set - 2016.12.13 @ 14.47.25 on A208.txt
    TEST CONDITIONS:
    Drive Model: Samsung SSD 850 EVO mSATA 250GB
    Graphics RAM: 1GB
    RFO >
    December 9, 2010
    Erie, PA
    15
    06:05 PM
    RVT 2016 - Standard set - 2017.01.10 @ 10.09.35 on DEMOK140Q-36
    RevitForum.org
    Run on Autodesk Revit 2016 Update2 for R2
    Update
    11.27 update previous version file
    3.21 opening and loading the custom template
    11.71 creating the floors levels and grids
    25.14 creating a group of walls and doors
    48.71 modifying the group by adding a curtain wall
    15.25 creating the exterior curtain wall
    9.18 creating the sections
    5.24 changing the curtain wall panel type
    11.35 creating area plans *
    131.23 TOTAL
    Notes:
    Export benchmark
    66.34 export all views as PNGs at 300 dpi
    51.40 export all views as DWFs
    107.04 export all views as DWGs
    59.35 print all views as vector *
    146.64 print all views as raster *
    Notes:
    Render benchmark
    164.55 render w/ nvidia mental ray
    Graphics benchmark
    9.54 refresh Hidden Line view x12
    9.30 refresh Consistent Colors view x12
    10.60 refresh Realistic view x12
    8.86 rotate view x1
    Notes:
    Results saved to: RVT 2016 - Standard set - 2017.01.10 @ 10.09.35 on DEMOK140Q-36.txt
    TEST CONDITIONS:
    Mfr: VMware, Inc.
    Model: VMware Virtual Platform
    OS: Microsoft Windows 7 Enterprise -bit
    CPU:
    Max Clock Speed: 0Ghz
    Drive Model: VMware Virtual disk SCSI Disk Device
    Graphics Card: NVIDIA GRID K140Q
    Graphics RAM: 1GB
    Driver version: 9.18.13.4827
    Graphics Card: VMware SVGA 3D
    Graphics RAM: 0.0078125GB
    Driver version: 8.15.1.45
    RFO >
    January 3, 2013
    1
    02:05 PM
    RVT 2016 - Standard set - 2017.01.15 @ 16.30.51 on XSUBMARINER-10
    RevitForum.org
    Update
    7.29 update previous version file
    2.54 opening and loading the custom template
    7.88 creating the floors levels and grids
    15.76 creating a group of walls and doors
    28.64 modifying the group by adding a curtain wall
    8.83 creating the exterior curtain wall
    6.47 creating the sections
    3.01 changing the curtain wall panel type
    6.89 creating area plans *
    1.05 creating and applying view template *
    81.07 TOTAL
    Notes:
    Export benchmark
    50.92 export all views as PNGs at 300 dpi
    70.60 export all views as DWFs
    81.98 export all views as DWGs
    45.87 print all views as vector *
    75.03 print all views as raster *
    Notes:
    Render benchmark
    74.51 render w/ nvidia mental ray
    Graphics benchmark
    4.03 refresh Hidden Line view x12
    3.73 refresh Consistent Colors view x12
    4.53 refresh Realistic view x12
    1.36 rotate view x1
    Notes:
    Results saved to: RVT 2016 - Standard set - 2017.01.15 @ 16.30.51 on XSUBMARINER-10.txt
    TEST CONDITIONS:
    Total Physical Memory: 32GB @ 3100 3100 3100 3100Mhz
    Drive Model: Samsung SSD 850 PRO 512GB
    Graphics Card: NVIDIA GeForce GTX 980 Ti
    Driver version: 21.21.13.7254
    RFO >
    December 12, 2016
    3
    10:05 PM
    RVT 2016 - Standard set - 2017.02.21 @ 22.45.58 on DESKTOP-8DU0AUF
    RevitForum.org
    Update
    8.01 update previous version file
    2.67 opening and loading the custom template
    8.32 creating the floors levels and grids
    16.78 creating a group of walls and doors
    32.09 modifying the group by adding a curtain wall
    9.33 creating the exterior curtain wall
    6.41 creating the sections
    3.36 changing the curtain wall panel type
    6.97 creating area plans *
    1.16 creating and applying view template *
    87.09 TOTAL
    Notes:
    Export benchmark
    54.96 export all views as PNGs at 300 dpi
    81.26 export all views as DWFs
    92.84 export all views as DWGs
    51.34 print all views as vector *
    80.24 print all views as raster *
    Notes:
    Render benchmark
    105.75 render w/ nvidia mental ray
    Graphics benchmark
    5.19 refresh Hidden Line view x12
    4.77 refresh Consistent Colors view x12
    5.73 refresh Realistic view x12
    1.61 rotate view x1
    Notes:
    Results saved to: RVT 2016 - Standard set - 2017.02.21 @ 22.45.58 on DESKTOP-8DU0AUF.txt
    TEST CONDITIONS:
    Mfr: To Be Filled By O.E.M.
    Model: To Be Filled By O.E.M.
    CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
    Drive Model: NVMe Samsung SSD 950
    Graphics Card: AMD Radeon (TM) R9 Fury Series
    Driver version: 21.19.137.514
    RFO >
    December 12, 2016
    3
    10:05 PM
    RVT 2016 - Standard set - 2017.02.21 @ 11.06.43 on A0XXSETUP101
    RevitForum.org
    Update
    8.78 update previous version file
    3.07 opening and loading the custom template
    11.02 creating the floors levels and grids
    19.68 creating a group of walls and doors
    35.01 modifying the group by adding a curtain wall
    11.61 creating the exterior curtain wall
    8.98 creating the sections
    3.88 changing the curtain wall panel type
    9.65 creating area plans *
    1.45 creating and applying view template *
    104.35 TOTAL
    Notes:
    Export benchmark
    65.47 export all views as PNGs at 300 dpi
    89.28 export all views as DWFs
    103.25 export all views as DWGs
    57.90 print all views as vector *
    94.31 print all views as raster *
    Notes:
    Render benchmark
    91.85 render w/ nvidia mental ray
    Graphics benchmark
    5.33 refresh Hidden Line view x12
    4.92 refresh Consistent Colors view x12
    5.96 refresh Realistic view x12
    2.68 rotate view x1
    Notes:
    Results saved to: RVT 2016 - Standard set - 2017.02.21 @ 11.06.43 on A0XXSETUP101.txt
    TEST CONDITIONS:
    Mfr: HP
    Model: HP Z2 Mini G3 Workstation
    CPU: Intel(R) Xeon(R) CPU E3-1245 v5 @ 3.50GHz
    Total Physical Memory: 32GB @ 2133 2133Mhz
    Drive Model: NVMe SAMSUNG MZVPV512
    Graphics Card: NVIDIA Quadro M620
    Graphics RAM: 2GB
    Driver version: 21.21.13.7295
    RFO >
  1. RFO Benchmark v3
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: August 28th, 2017, 01:18 AM
  2. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  3. RFO Benchmark v2 2016 call for testers
    Last Post: November 18th, 2015, 08:18 PM
  4. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 02:08 PM
