Results 1 to 3 of 3
Thread: RFO Benchmark v3 2015 results
    Rotterdam, South Holland
    2,948
    03:44 AM
    Please post your RFOBenchmark V3 results for the 2015 products here.
    Comments and suggestions should be made in the RFOBenchmark v3 thread. The download is there too.
    Thanks!
    Gordon
    Member Iberkim's Avatar
    June 24, 2016
    Denmark
    81
    04:44 AM
    My old computer:
    RVT 2015 - Standard set - 2017.06.22 @ 11.31.33 on DK-GCE-HNB0-004
    RFO Benchmark v3.0 (build 17.10.2016)
    RevitForum.org
    All times are in seconds, lower is better.
    Run on Autodesk Revit 2015 UR14
    __________________________________________________ _______________
    Update
    19.33 update previous version file
    Model creation benchmark
    3.65 opening and loading the custom template
    16.60 creating the floors levels and grids
    29.68 creating a group of walls and doors
    50.47 modifying the group by adding a curtain wall
    19.00 creating the exterior curtain wall
    13.97 creating the sections
    6.52 changing the curtain wall panel type
    14.02 creating area plans *
    2.18 creating and applying view template *
    156.09 TOTAL
    Notes:
    * Area and View Template sections are not processed by Revit Structure
    Export benchmark **
    84.48 export all views as PNGs at 300 dpi
    121.10 export all views as DWFs
    156.16 export all views as DWGs
    78.05 print all views as vector *
    150.07 print all views as raster *
    Notes:
    * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    ** Revit Structure export times cannot be compared with other verticals
    as view counts are different
    Render benchmark
    245.60 render w/ nvidia mental ray
    Graphics benchmark
    9.79 refresh Hidden Line view x12
    9.85 refresh Consistent Colors view x12
    11.25 refresh Realistic view x12
    4.48 rotate view x1
    Notes:
    Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    To meaningfully compare graphics cards, test all cards in the same machine
    and use the 'Graphics - expanded' benchmark.
    Raw Data
    20.238 18.848 18.906 update previous version file
    3.512 3.918 3.520 opening and loading the custom template
    16.750 16.379 16.672 creating the floors levels and grids
    29.883 29.617 29.555 creating a group of walls and doors
    50.367 50.715 50.324 modifying the group by adding a curtain wall
    19.430 18.856 18.703 creating the exterior curtain wall
    14.051 13.934 13.926 creating the sections
    6.457 6.606 6.492 changing the curtain wall panel type
    14.332 13.719 14.020 creating area plans
    2.090 2.055 2.410 creating and applying view template
    83.996 85.148 84.285 export all views as PNGs at 300 dpi
    121.547 120.801 120.965 export all views as DWFs
    156.695 155.586 156.195 export all views as DWGs
    78.453 77.191 78.520 print all views as vector
    150.738 150.285 149.184 print all views as raster
    252.887 242.695 241.227 render w/ nvidia mental ray
    9.723 9.758 9.879 refresh Hidden Line view x12
    9.762 9.789 10.012 refresh Consistent Colors view x12
    11.480 11.062 11.219 refresh Realistic view x12
    4.473 4.547 4.414 rotate view x1
    MACHINE SPEC:
    Mfr: Hewlett-Packard
    Model: HP EliteBook 8570p
    OS: Microsoft Windows 7 Enterprise 64-bit
    CPU: Intel(R) Core(TM) i7-3540M CPU @ 3.00GHz
    Max Clock Speed: 3.001Ghz
    Number of Processors: 2
    Number of Logical Processors: 4
    Total Physical Memory: 12GB @ 1600 1600Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: KINGSTON SV300S37A240G
    Graphics Card: AMD Radeon HD 7570M
    Graphics RAM: 1GB
    Driver version: 8.951.6.2200
    Screen Resolution: 1920x1200x32bit @ 60Hz
    June 24, 2016
    Denmark
    81
    04:44 AM
    My new computer
    RVT 2015 - Standard set - 2017.06.22 @ 09.35.22 on DK-GCE-LNB0-026
    RevitForum.org
    Update
    16.21 update previous version file
    3.46 opening and loading the custom template
    12.58 creating the floors levels and grids
    21.89 creating a group of walls and doors
    38.74 modifying the group by adding a curtain wall
    13.93 creating the exterior curtain wall
    10.58 creating the sections
    4.75 changing the curtain wall panel type
    11.06 creating area plans *
    1.80 creating and applying view template *
    118.79 TOTAL
    Notes:
    Export benchmark **
    75.36 export all views as PNGs at 300 dpi
    100.84 export all views as DWFs
    119.37 export all views as DWGs
    68.38 print all views as vector *
    106.72 print all views as raster *
    Notes:
    Render benchmark
    106.39 render w/ nvidia mental ray
    Graphics benchmark
    6.19 refresh Hidden Line view x12
    6.36 refresh Consistent Colors view x12
    7.26 refresh Realistic view x12
    2.40 rotate view x1
    Notes:
    Raw Data
    16.312 16.129 16.184 update previous version file
    3.523 3.465 3.402 opening and loading the custom template
    12.887 12.648 12.203 creating the floors levels and grids
    22.059 21.410 22.203 creating a group of walls and doors
    38.871 38.723 38.637 modifying the group by adding a curtain wall
    14.039 13.770 13.973 creating the exterior curtain wall
    11.125 10.285 10.316 creating the sections
    5.000 4.586 4.664 changing the curtain wall panel type
    11.637 10.746 10.789 creating area plans
    1.894 1.730 1.770 creating and applying view template
    75.324 75.441 75.312 export all views as PNGs at 300 dpi
    100.953 100.742 100.816 export all views as DWFs
    119.281 119.223 119.609 export all views as DWGs
    68.340 68.316 68.492 print all views as vector
    107.301 106.449 106.414 print all views as raster
    106.508 106.402 106.254 render w/ nvidia mental ray
    6.176 6.223 6.172 refresh Hidden Line view x12
    6.324 6.344 6.426 refresh Consistent Colors view x12
    7.297 7.227 7.242 refresh Realistic view x12
    2.434 2.387 2.379 rotate view x1
    MACHINE SPEC:
    Mfr: LENOVO
    Model: 20EQS0FY16
    OS: Microsoft Windows 10 Enterprise64-bit
    CPU: Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz
    Max Clock Speed: 2.712Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 31GB @ 2133 2133 2133 2133Mhz
    Drive Model: THNSN5512GPU7 TOSHIBA
    Graphics Card: NVIDIA Quadro M2000M
    Graphics RAM: 3.9990234375GB
    Driver version: 21.21.13.7691
    Graphics Card: Intel(R) HD Graphics 530
    Graphics RAM: 1GB
    Driver version: 21.20.16.4550
    Screen Resolution: 1920x 1080x32bit @ 60Hz
  1. RFOBenchmark 2015 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: August 13th, 2016, 11:59 AM
  2. RFOBenchmark Results 11.16.2015 07-46 REVIT-PC (RVT)
    By sandeep in forum Hardware and Infrastructure
    Last Post: November 17th, 2015, 05:31 AM
  3. RFO Benchmark 2013 results - Citrix Xenapp
    By Markus in forum Hardware and Infrastructure
    Last Post: September 18th, 2014, 02:08 PM
