Donate Now Goal amount for this year: 3000 USD, Received: 2285 USD (76%)
Page 2 of 10 FirstFirst 123456 ... LastLast
Results 11 to 20 of 96
Like Tree2Likes
Thread: RFO Benchmark v2
  1. #11
    Rotterdam, South Holland
    2,977
    03:40 AM
    Morten, and anyone else having issues with the v2 benchmark, please PM me at your convenience and we'll set up a time for tomorrow or Wednesday to GTM and sort things out.
    Thanks!
    Gordon
    Alex Cunningham likes this.
  2. #12
    Coeur d Alene, ID
    4,236
    06:40 PM
    6700k results are up....going to be interesting when Aaron get's his screaming laptop...
  3. #13
    8,825
    08:40 PM
    It will be a while: The screaming laptop is coming when Employee Number 2 "officially" joins (and since people in the rumor mill always talk, its NOT Alison...), or when a project warrants it. The HP ZBook i have currently is more than fitting the bill for what i am working on right now, and getting the Synology up and running is the first task. I just learned how to expand the Synology top 16GB of onboard RAM, so thats this weekends task. =)
  4. #14
    February 6, 2012
    3
    06:40 PM
    I'm trying to test the benchmark on a SurfaceBook i5 with dGPU 8GB RAM and 256 SSD. This PC is running Windows 10, and only has v2016 of Building Design Suite Ultimate installed.but can't get it to run even the 'Simplified' version....I only have the SurfaceBook on loan for the rest of today and would like to get an idea of how it performs with this benchmark. Will the old version of the 2015 test work in 2016 on Windows 10?
  5. #15
    Member TRWhitehead's Avatar
    February 16, 2012
    Portland, OR
    327
    06:40 PM
    Gordon,
    I tried this yesterday with a freshly imaged Dell M3800 running win10 and it wouldn't run one of the Journals. Specifically it stopped somewhere in the midst of 1-RFO_Benchmark_v1_Journal_2016_(Model_creation).txt while editing one of the groups. It drops into interactive mode at that point and I'm figuring it will fail the whole thing but continues with the next journal after I kill revit. Revit 2016 R2 (fresh install) and Revit does launch without issue.
    Any ideas?
  6. #16
    May 13, 2014
    Brazil
    5
    11:40 PM
    Hello Gordon,
    I got similar problem, check the screen below
  7. #17
    Coeur d Alene, ID
    4,236
    06:40 PM
    Quote Originally Posted by TRWhitehead View Post
    Gordon,
    Any ideas?
    Mine stopped working when I got R2 installed...
  8. #18
    2,977
    03:40 AM
    Tom,
    you need to use the kill script or it will keep processing journals. I looked for a way for the script to effectively be its own kill switch, but Powershelgl can't spawn a completely independent monitoring process.
    I'll be looking into this dropping in to interactive issue next week. I have some other stuff that needs to take priority, but I have to make time for some benchmark work on Friday.
  9. #19
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    246
    03:40 AM
    Hi, Gordon
    Benchmark worked for an hour and a half, and spit only this (plus error code that fabiosato already submitted):
    Code:
    RFO Benchmark v2 - RVT 2016   'Standard' Test Set   2015.11.09 @ 09.03.55 on I7-4770WS
     build: 22.09.2015
     RevitForum.org
     All times are in seconds, lower is better.
     Model creation and view export benchmark
         0.00   opening and loading the custom template
         0.00   creating the floors levels and grids
         0.00   creating a group of walls and doors
         0.00   modifying the group by adding a curtain wall
         0.00   creating the exterior curtain wall
         0.00   creating the sections
         0.00   changing the curtain wall panel type
         0.00   export all views as PNGs at 150 dpi
         0.00   export some views as DWGs
         0.00   TOTAL
     Render benchmark
         0.00   render w/ nvidia mental ray
     v1 Graphics benchmark w/ hardware acceleration [1]
         0.00   refresh Hidden Line view x12 - with hardware acceleration
         0.00   refresh Consistent Colors view x12 - with hardware acceleration
         0.00   refresh Realistic view x12 - with hardware acceleration
         0.00   rotate view x1 - with hardware acceleration
     v1 Graphics benchmark w/o hardware acceleration [2]
         0.00   refresh Hidden Line view x12 - without hardware acceleration
         0.00   refresh Consistent Colors view x12 - without hardware acceleration
         0.00   refresh Realistic view x12 - without hardware acceleration
         0.00   rotate view x1 - without hardware acceleration
     [1] Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
         To meaningfully compare graphics cards, test all cards in the same machine
         and use the 'v2 Graphics - expanded' benchmark.
     [2] For comparison with Hardware Accelerated graphics.
     MACHINE SPEC:
     Mfr: To Be Filled By O.E.M.
     Model: To Be Filled By O.E.M.
     OS: Microsoft Windows 8.1 Pro64-bit
     CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
     Max Clock Speed: 3.401Ghz
     Number of Processors: 4
     Number of Logical Processors: 8
     Total Physical Memory: 16GB @ 1333 1333Mhz
     Graphics Card: NVIDIA GeForce GTX 760
     Graphics RAM: 2GB
     Driver version: 10.18.13.5887
     Graphics Card: Intel(R) HD Graphics 4600
     Graphics RAM: 1GB
     Driver version: 10.18.10.3960
     Screen Resolution: 2560 1600x1440 1200x32bit @ 59 60Hz
     Benchmark did run full screen
  10. #20
    2,977
    03:40 AM
    Quote Originally Posted by Hirvio View Post
    Hi, Gordon
    Benchmark worked for an hour and a half, and spit only this ...
    That's my decimal bug. When your machine is set to use the European format (#.###,00) rather than the US format (#,###.00) the code barfs when trying to do math on the results. I had initially tried to change the machine settings before the test, then change them back. But I don't like that because a terminated test could leave the machine configured wrong. Now I am looking for a way to either force PowerShell to do the math with European decimal delimiters, or do some sort of find and replace to convert to US delimiters, then do the math, then switch back for display. Pretty sure PowerShell is internally a US format only situation, so I am playing with the conversions approach on the flight home. But a little research today says that there is another format I need to look for (# ###,00). So, yeah, I am getting an education on global maths.
    EDIT: Seems it might not be that simple, or at least I might not be on the right track. Can you maybe run the test again, and once the graphics test starts, grab a copy of the temporary output file and email it to me? Then I can be sure I am working from actual raw data that is misbehaving. Thanks!
    Gordon
  1. RFO Benchmark decision thresholds
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: August 2nd, 2015, 07:36 PM
  2. Can't get 2013 Benchmark running
    By brett05 in forum Hardware and Infrastructure
    Last Post: December 11th, 2013, 08:48 PM
  3. RFO 3DMax Rendering Benchmark
    By gaby424 in forum Hardware and Infrastructure
    Last Post: February 7th, 2012, 12:25 AM
  4. CPU benchmark 3Ddmax Mental Ray
    Last Post: May 14th, 2011, 07:37 PM
