Page 10 of 10 FirstFirst ... 678910
Results 91 to 96 of 96
Like Tree2Likes
Thread: RFO Benchmark v2
  1. #91
    January 10, 2017
    1
    04:51 PM
    Hello, will there be a benchmark published for 2017 anytime soon?
    Thanks
  2. #92
    December 9, 2010
    Erie, PA
    15
    05:51 PM
    Didn't find a V2 Results thread!
    RFO Benchmark v2.1 - RVT 2016 'Standard' Test Set 2017.01.11 @ 17.45.20 on DEMOK140Q-36
    build: 19.01.2016
    RevitForum.org
    All times are in seconds, lower is better.
    Model creation and view export benchmark
    3.91 opening and loading the custom template
    12.07 creating the floors levels and grids
    26.08 creating a group of walls and doors
    49.68 modifying the group by adding a curtain wall
    15.80 creating the exterior curtain wall
    10.11 creating the sections
    5.79 changing the curtain wall panel type
    38.39 export all views as PNGs at 150 dpi
    35.29 export some views as DWGs
    197.12 TOTAL
    Render benchmark
    159.87 render w/ nvidia mental ray
    v1 Graphics benchmark w/ hardware acceleration [1]
    9.39 refresh Hidden Line view x12 - with hardware acceleration
    9.08 refresh Consistent Colors view x12 - with hardware acceleration
    10.17 refresh Realistic view x12 - with hardware acceleration
    8.83 rotate view x1 - with hardware acceleration
    v1 Graphics benchmark w/o hardware acceleration [2]
    107.57 refresh Hidden Line view x12 - without hardware acceleration
    108.47 refresh Consistent Colors view x12 - without hardware acceleration
    110.22 refresh Realistic view x12 - without hardware acceleration
    87.75 rotate view x1 - without hardware acceleration
    [1] Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
    To meaningfully compare graphics cards, test all cards in the same machine
    and use the 'v2 Graphics - expanded' benchmark.
    [2] For comparison with Hardware Accelerated graphics.
    MACHINE SPEC:
    Mfr: VMware, Inc.
    Model: VMware Virtual Platform
    OS: Microsoft Windows 7 Enterprise -bit
    CPU:
    Max Clock Speed: 0Ghz
    Number of Processors:
    Number of Logical Processors:
    Total Physical Memory: 16GB @ Mhz
    Graphics Card: NVIDIA GRID K140Q
    Graphics RAM: 1GB
    Driver version: 9.18.13.4827
    Graphics Card: VMware SVGA 3D
    Graphics RAM: 0.0078125GB
    Driver version: 8.15.1.45
    Screen Resolution: xx32bit @ Hz
    Benchmark did run full screen
    __________________________________________________ __________
    Raw Data
    4.117 3.828 3.781 opening and loading the custom template
    12.973 11.703 11.539 creating the floors levels and grids
    27.738 25.328 25.188 creating a group of walls and doors
    50.980 48.578 49.469 modifying the group by adding a curtain wall
    16.344 15.500 15.555 creating the exterior curtain wall
    10.836 9.789 9.703 creating the sections
    6.004 5.648 5.703 changing the curtain wall panel type
    39.574 37.297 38.312 export all views as PNGs at 150 dpi
    36.394 34.617 34.867 export some views as DWGs
    164.832 152.930 161.852 render w/ nvidia mental ray
    9.363 9.344 9.453 refresh Hidden Line view x12 - with hardware acceleration
    9.086 9.070 9.078 refresh Consistent Colors view x12 - with hardware acceleration
    10.148 10.180 10.195 refresh Realistic view x12 - with hardware acceleration
    8.824 8.859 8.805 rotate view x1 - with hardware acceleration
    108.387 107.312 107.016 refresh Hidden Line view x12 - without hardware acceleration
    110.039 108.414 106.969 refresh Consistent Colors view x12 - without hardware acceleration
    111.191 110.703 108.766 refresh Realistic view x12 - without hardware acceleration
    88.184 88.336 86.742 rotate view x1 - without hardware acceleration
  3. #93
    December 9, 2010
    Erie, PA
    15
    05:51 PM
    RFO Benchmark v2.1 - RVT 2016 'Standard' Test Set 2017.01.11 @ 17.08.36 on WMF-SAV1-010
    build: 19.01.2016
    RevitForum.org
    8.46 opening and loading the custom template
    24.77 creating the floors levels and grids
    53.07 creating a group of walls and doors
    83.65 modifying the group by adding a curtain wall
    28.99 creating the exterior curtain wall
    19.31 creating the sections
    9.67 changing the curtain wall panel type
    64.44 export all views as PNGs at 150 dpi
    71.45 export some views as DWGs
    363.81 TOTAL
    Render benchmark
    285.50 render w/ nvidia mental ray
    13.21 refresh Hidden Line view x12 - with hardware acceleration
    12.77 refresh Consistent Colors view x12 - with hardware acceleration
    15.11 refresh Realistic view x12 - with hardware acceleration
    6.27 rotate view x1 - with hardware acceleration
    135.98 refresh Hidden Line view x12 - without hardware acceleration
    136.70 refresh Consistent Colors view x12 - without hardware acceleration
    139.34 refresh Realistic view x12 - without hardware acceleration
    113.49 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    Mfr: Xen
    Model: HVM domU
    OS: Microsoft Windows 8.1 Enterprise64 64-bit
    CPU: Intel(R) Xeon(R) CPU E5-2637 v2 @ 3.50GHz Intel(R) Xeon(R) CPU E5-2637 v2 @ 3.50GHz
    Max Clock Speed: Ghz
    Number of Processors: 2 2
    Number of Logical Processors: 2 2
    Graphics RAM: 0.9375GB
    Driver version: 9.18.13.3283
    Graphics Card: Citrix Display Driver (Citrix Systems - WDDM)
    Graphics RAM: 0GB
    Driver version: 7.6.0.5006
    Screen Resolution: 1920 1920x1200 1200x32bit @ 29 29Hz
    Raw Data
    7.535 10.949 6.883 opening and loading the custom template
    24.879 24.953 24.492 creating the floors levels and grids
    55.762 54.121 49.312 creating a group of walls and doors
    83.984 85.676 81.281 modifying the group by adding a curtain wall
    31.344 28.430 27.211 creating the exterior curtain wall
    19.410 18.723 19.805 creating the sections
    10.297 9.629 9.094 changing the curtain wall panel type
    64.398 66.285 62.633 export all views as PNGs at 150 dpi
    78.707 72.910 62.719 export some views as DWGs
    296.344 286.078 274.070 render w/ nvidia mental ray
    13.613 13.352 12.664 refresh Hidden Line view x12 - with hardware acceleration
    13.453 12.820 12.023 refresh Consistent Colors view x12 - with hardware acceleration
    15.641 15.141 14.555 refresh Realistic view x12 - with hardware acceleration
    7.074 6.078 5.648 rotate view x1 - with hardware acceleration
    141.703 135.305 130.930 refresh Hidden Line view x12 - without hardware acceleration
    139.965 137.672 132.477 refresh Consistent Colors view x12 - without hardware acceleration
    145.047 139.227 133.758 refresh Realistic view x12 - without hardware acceleration
    120.719 110.289 109.461 rotate view x1 - without hardware acceleration
  4. #94
    Rotterdam, South Holland
    2,949
    11:51 PM
    Quote Originally Posted by rspeicher View Post
    That's my fault. I tried to consolidate the three year threads, and I jacked it up and deleted it instead, and I deleted it right after I consolidated, so it isn't easily restorable. I think that might have been on Monday the 13th. It was early. I had only had one cup of coffee.
    But I have found almost all of it on the Wayback Machine, and I am working on a manual "restore". Trying to wrap that up this weekend.
    Sorry for the inconvenience everyone!
    Gordon
  5. #95
    December 23, 2010
    1
    05:51 PM
    Any update? Same issue happening here.
    Quote Originally Posted by Linn Bjornrud View Post
    Update: As a test we edited the script to omit a series of actions around the point where the error was occurring. Upon doing this, we were able to run the journal file successfully on all machines. This doesn't explain the issue, but it does pinpoint the problem area in the script ("Modifying the group by adding a curtain wall").
    Since we primarily need to test machines against each other internally, this will work for us. We will not, however, post our results on the forum as it will not be a fair comparison to others based on our modifications.
    Any update to this issue? I'm having exactly the same thing happen here.
    Windows 7 Enterprise, 64bit, Revit 2016 R2 update 7, nVidia Quadro k2100m
    Thanks
  6. #96
    2,949
    11:51 PM
    I have managed to isolate one possible cause, IF the failure is in the Export test, it seems to be related to the VBScript code in the journal not recognizing that the required printer isn't available. Anyone who is having this issue, please DM me so I can get a copy of your failure journal and verify if everyone is having the same issue.
    Thanks!
    Gordon
  1. RFO Benchmark decision thresholds
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: August 2nd, 2015, 07:36 PM
  2. Can't get 2013 Benchmark running
    By brett05 in forum Hardware and Infrastructure
    Last Post: December 11th, 2013, 08:48 PM
  3. RFO 3DMax Rendering Benchmark
    By gaby424 in forum Hardware and Infrastructure
    Last Post: February 7th, 2012, 12:25 AM
  4. CPU benchmark 3Ddmax Mental Ray
    Last Post: May 14th, 2011, 07:37 PM
