Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By Twiceroadsfool
Thread: Persistence of help video
    Junior Member Stets's Avatar
    June 6, 2011
    Oakland, CA
    12
    08:33 PM
    I'm not sure this is a hardware problem but I don't know where else to post this.
    Problem: The help videos that drop down from the ribbon when you cursor over a tool sometimes remain on the screen and will only go away if I restart Revit. Is anyone else having this problem? I'm using RAC2012 on an ASUS G73SW-XA1 with an NVIDIA GeForce GTX 460M video controller. The problem is intermittent but happens frequently enough to be really annoying. Is there an option to turn off these "helpful" videos so they don't have an opportunity to get in my way in the first place?
    Jim
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    782
    04:33 PM
    Quote Originally Posted by Stets View Post
    Jim
    Not sure why the ToolClip video would remain showing after you have moved off of the tool. Probably a driver problem, or a problem with your Flash installation.
    If you want them to NEVER show then you can set you Tooltip asistance level to "None" or "Minimal". You will then never see the level 2 tooltip text. If you still want the level 2 text from the tool tip there is no way to get that without the video playing. The tooltip asistance level is set in the User interface tab of the options dialog.
    June 6, 2011
    Oakland, CA
    12
    08:33 PM
    Hi Jeff,
    I verified my drivers are up to date and I re-installed both Flash 10 Active X and Flash 10 Plugin but I'm still having the same problem. After I start Revit I cursor-over the tools to see if the ToolClip is going to misbehave and it usually doesn't. But after I've been working on my model for a while and then cursor-over one of the tools lthat has a ToolClip, it will leave a copy of the video on the display after I move the cursor off the tool. Do you think it could have anything to do with Flash being 32-bit? There is a "Preview" available of the 64-bit version but I don't know if I want to do beta testing for Adobe right now--I'm kinda busy.
    Thanks,
    Jim
    Senior Member rkitect's Avatar
    April 21, 2011
    Oklahoma
    773
    03:33 PM
    I've had this happen before and I attribute it to moving the cursor off the ribbon too fast. The same thing happens with flash menus on websites; you can trick them into thinking the mouse is still hovering over the menu if you "leave" the button area in the right direction and speed. To get it to go away I am usually able to just go back to that tool and hover over it again until the video goes away or if that doesn't work, wait for the tooltip to expand out to the video again and this time exit the buttonArea a bit slower.
    HTH.
    December 13, 2010
    782
    04:33 PM
    Hi Jeff,
    Thanks,
    Jim
    You may also want to see if the flash plug in for internet explorer is up todate. Somehow the ToolClip leverages this player in IE inorder to play the clip. That is the only thing I can think of. I am not super clear on all of the "nuts and blots" of how the thing work behind the scenes. You have just about exhausted my knowledge on the subject.
    June 6, 2011
    Oakland, CA
    12
    08:33 PM
    Quote Originally Posted by revittotd View Post
    HTH.
    Good ideas. I tried sneaking up on it, sneaking away from it, everything short of putting the computer on the floor and jumping up and down on it. It's really strange. I can work for a couple hours and everything's fine. Then, just when I've almost forgotten about it, there it goes again. I think I'll just try minimizing the tooltip help as Jeff suggested.
    Thanks for your help,
    Jim
    Member Geert's Avatar
    February 8, 2011
    Les Vigneaux, Hautes Alpes, France
    145
    10:33 PM
    I am still seeing this problem in 2013 on an ATI Firepro M7740 on the latest drivers.
    So it seems not to be eigther card or driver related. I will try the flash player.
    May 1, 2015
    1
    06:33 AM
    I end up with two windows residing on the screen! This seems to depend upon which help clip is opened some go back home nicely others stick like a limpet. Installed a new graphics card and the problem is still with me. Ideas?
    10,354
    03:33 PM
    You can kill the adflash process in task manager and shut them down. That'd what I do.
    iru69 and ayelsea like this.
    New Member ayelsea's Avatar
    November 30, 2015
    California
    2
    12:33 PM
    Great advice!
  1. Revit Hardware : Video Graphic Cards
    By iru69 in forum Hardware and Infrastructure
    Last Post: December 17th, 2018, 10:36 PM
  2. Revit Video Tutorials for beginners
    By JCM in forum Tutorials, Tips & Tricks
    Last Post: June 20th, 2011, 11:59 PM
  3. Revit 2012 assemblies - CADclips video
    By willsud in forum Tutorials, Tips & Tricks
    Last Post: May 4th, 2011, 11:08 PM
  4. ATI Video card not working well.
    By Wadeshuey in forum Hardware and Infrastructure
    Last Post: April 22nd, 2011, 04:04 AM
