eTABS -> Revit
    eTABS -> Revit
    Please share any sucess or horror stories you may have about eTABS.
    -Alex Cunningham
    Hi Alex:
    this is a example application of csixrevit 2011:
    http://www.4shared.com/get/yc8-stSP/ejemplo.html
    regards
      Analysing storey building
      How can I impose load to the 3rd or 2nd floor of the building by using RST
        Recently I exported a model from ETABS, and now I'm not able to use the command place rebar, revit crashed every time I tried... Someone has lived this problem before?
          Rebar needs a host.
          Are your beams/columns/slabs (intelligent) objects?
          If you've exported just a 3D model, then Revit doesn't "see" the columns or beams as viable host elements for reinforcement.
          Revit Architecture 2013 Certified Professional
            I created my beams and columns types from the revit basics, and but I will try to load the families again, and see what happen. Thanks for answer! I will post the result soon.
              We also just started a project with the Str Eng using ETABs. Any advice or stories appreciated..
