Beam Joins for Concrete Rectangular Beams
    When I use the Beam or Column Joins command, I got a problem.
    Eventhough I checked all of the "Steel" "Wood" "Precast Concrete" and "Other",
    I only can edit the Joins for the first three categories but the "Other" doesn't effect to my "Concrete Rectangular Beam".
    Is it the normal behaviour of the command or something wrong with my software?
    For ref: I attached the print screen.
    Thanks.
    Additional info
    Actually, My intension to do so is especially for my Concrete Rectangular Beam to be joined as a miter join.
    As attachment.
    Thanks.
      Concrete (cast in place, not precast) beam join cleanup is automatic. You may be able to modify the join by changing the beam creation order, but I doubt that would give you what you want in this case.
      The Beam Join Editor tool works for Framing families that have a structural Material that is not "Concrete".
      You are not missing anything- that's the way Revit works.
      Joe
