Visual Problem
    Visual Problem
    I have found that the visual for the Steel Beam Joints appears differently as shown in attachment.
    Any way to be able to see to be the same?
    Or is it possible to visualize the connection with no gaps at the joint?
    Any view setting to change.
    thanks.
    Which way do you want them to look? Like on the left as continuous? Or on the right with a break between the ends?
    First thing I'd check is the elevation(s) of the ends of the beams and the elevation of the girder where they bear.
    Leanne Zaras, CDT, LEED AP
      This is my project file (Version RST 2011)
      please kindly point out my fault.
      I just want the same viewing for the connections in either way of at the centre or at the continuous joint.
      Thanks.
        Leanne's right, be sure both of your CSB2 are configured the same way and at the same elevation.
        If you wan't to have the same result, you could try to place both your beams all the way and then split them at the same place.
        Alexandre Cantin
