Stair & Slab Joint
    Stair & Slab Joint
    Any idea to join slab and staircase into one piece.
    I would like to do as attached, in my project.
    Please kindly help me.
    Unfortunately (wish listed), Join geometry doesn't work between Stairs and Slabs.
    You have 2 solutions :
    - Specify slab thickness but negative value of type parameter "Extend Below Base"
    - Add a slab edge profile
    But in both cases, play with Linework (LW) tool to override common lines as invisible.
      Thank you very much indeed!
