So using real rebar (not area/path) when you create bars in a view they are defaulted to have the check box "Unobstructed In View" checked in that view. Is there anyway to over ride this so that is not checked by default?
Rebar AGAIN
Originally posted by gdoherty0102 View PostSo using real rebar (not area/path) when you create bars in a view they are defaulted to have the check box "Unobstructed In View" checked in that view. Is there anyway to over ride this so that is not checked by default?
ErikErik Snell, P.E.
Factory Worker (Principal User Experience Designer)
I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
👍 1
I kind of figured that was the reason why. I think I recall from RST 1 or 2 that they did not have this and so every time you placed bars it would give you the error about items you just placed are not visible in view. I will try unchecking this prior to placement and see if it works. Thank!
Greetings from Texas! I'm trying to learn how to detail rebar in Revit Structure 2012 for concrete reinforcement. I went through an intense week long...
January 9, 2012, 11:48 AM -
I modeled floor slabs, from there I went to section views and placed Rebar in them. I had to make some changes and add more Rebar after that. I see that...
January 19, 2012, 05:46 PM -
I was tinkering around with the rebar placement and got it working (woo!) but the rebar shows up in all my sections, even when it should be covered by...November 26, 2013, 08:57 PM
Hello All
This is the first time I have run into this error.
I have a concrete slab and have modelled it with the area reinf...-
September 10, 2013, 01:05 PM -
Hi all,
In the image provided you can see a rebar stirup in plan view.
The issue is that part of the rebar is displaying as...-
December 21, 2016, 09:35 PM -
Monumetric Footer In-screen
