can I model a notched floor?
    is there a way to create a live floor slab with a notch? i need to start defining structure to this section and how this canopy joins with the floor
    thanks
    I'm pretty sure that you could use an in place void family, but if it's just for sections you could use the Cut Profile tool under View/Graphics/Cut Profile.
    Adam Hutchinson
    Engineer in Training
    Integrus Architecture, P.S.
      You could possibly also use a Slab Edge--( can't tell what type of floor you are using?)
      Cliff B. Collins
      Registered Architect
      Autodesk Expert Elite
        No In-Place Please
        Slab Edges should be best. BTW: do not (EVER) use in-place families (mostly), unless you want to add difficulties & unnecessary weight...
        -J
        http://about.me/JayZallan
        Tweet, Link or Blog me up!!!
          Hear hear... Slab edges for me too!
            useful advice, thanks guys. I had no clue what a slab edge was but this video is also pretty helpful for whoever wants a look
            Munkholm
            Administrator
              i like the tutorial.
              Very clear on how this could be done.
              Greetz Bross
              http://bross.webklik.nl/page/homepage
              www.vanbragtbv.nl
                does anyone know why when I create a slab edge, there is a line separating it from the slab? I want it to look as though it is a single formed element.slab edge.JPG
                  Two things to check:
                  1: Are they exactly the same material?
                  2: Try joining them.
                    Great! problem solved. Thanks Kim
