Joining wall with the slab
    Hi everyone,
    I need to create an underground concrete tank. Can you please tell me if I can join walls with the slab?
    This is what I've got:
    Revit Architecture 2013 Certified Professional
    You can, but they need to have the exact same material to Join properly...
      I've done that, but no luck.
      Please see atached:
        Once I opened your file I went in Modify --> Geometry --> Join
        I didn't modify the material you put.
        As you see on right the wall is joined with the slab... I don't know why it's not working for you.
        Alexandre Cantin
          I would like to change my status to "n00b".
          Thank you Alexandre.
            What is this... an inverted background???
              Yes! Actually, black backround prevents eye strain.
              Considering the fact that I'm working in front of my screen all day long, I'm trying to spare them.
              Moreover, black background uses less power.
              Alexandre Cantin
                Sorry I don't have 2012 version and so i can't open it.
                But actually it should be able to join it by using Geometry Join.
