Z-direction justification of a Revit Trusses
    Is there a way to adjust the Z-direction justification of a Revit trusses top and bottom cord? It seems to be set to center and that do. I also tried to adjust the analytical vertical projection and it does not adjust the Z-direction justification either. Am I missing something here?
    I need the top cords to be set to the Top of Beam and the bottom cord set to Bottom of beam. That way I can attach to our roof and it will apply to the bottom side of the roof sheathing.
    Hi
    select the top beam with tab, unpinned it, then adjust Z justification.
    Julien
    P. DAC
      But doesn’t that detach it from the truss?
      Isn’t there a way to adjust the top and bot cord Z-direction justification without destroying the truss?
        Try on a dummy one, move it, or trim it. works for me. You will have a warning, but that works. relationship is still here.
        Julien
        P. DAC
          Sweet! it worked!..... its not perfect but good for what im doing... for sure!
          Thanks for the input...
