Getting metadata out of Revit Structure 2010
    Hey all,
    Is there a way to run a report or something through BIM (Revit Structure 2010 is what we used for designing) to automatically extract metadata (Such as building #, sheet #, etc.) from the drawings to automatically place the drawings into a database? It sounds like Excel is going to be a factor, but looking for any help I can get. We do not want to manually type everything in.....twice. Thanks.
    If you have the parameters set up you should be able to create a sheet schedule that, with the right list of parameters selected, will show what you want. Then you can export via report to a .txt file. Then open that file in excel choosing the options you want in order to get the correct format you want.
    Adam Hutchinson
    Engineer in Training
    Integrus Architecture, P.S.
      If you are on subscription, you should try the DB Link:
      Autodesk Revit DB Link 2012
      Import and export data between an Autodesk® Revit® Architecture 2012, Autodesk® Revit® Structure 2012, or Autodesk® Revit® MEP 2012 project and an external database, and then more easily maintain relationships of linked data with Autodesk® Revit® DB Link.
      • A grid view of the data enables you to make any final edits before import.
      • Databases can be updated following internal or external changes.
      • The grid control enables you to create Revit shared parameters to add new fields to related tables in the database.
      • Changes to new fields within the database automatically update Revit shared parameters upon future imports.
        Thank you for commenting! You say export via a .txt file? I'm still just a little confused. By the way have you heard of COBie2?
          Thanks Klaus! is DB Link free and will it work with 2010?
            It´s free if you're on subscription, and yes, I believe there's a 2010 version too.
            Have a look here: Sign in to Subscription Center
              Haven't heard of COBie2 but if you go to the big R > Export > Reports > Schedule while you're in the schedule that you want to export. You'll get a dialog that asks you to save the file as a .txt, then you'll get another dialog and use the setup below to import easily into Excel.
              Adam Hutchinson
                It says that our Revit is not on subscription, but waiting for our contract number from a gentleman but I believe he took a three day weekend. Thanks for continuing to respond Klaus!
                  [ATTACH=CONFIG]4671[/ATTACH]
                  Thanks for your help Adam. I am playing around with this as well as seeing what the DB Link software has to offer. I can't thank you guys enough.
                    About exporting txt / importing to Excel, try this workflow:
                    1. Export all schedules needed
                    2. Open blank Excel file.
                    3. Select all files in Windows Explorer and drag them into your Excel screen. They will now open while retaining the txt-format and extension
                    4. In Excel go to cell A1 and type =. Now select cell A1 from the first schedule. It will show something like this = test$A$1. Manually remove the two dollar signs and hit enter
                    5. Select the dragmark at the right bottom corner of the cell and drag to the right to expand the coverage to all columns needed
                    6. Select the same dragmark and drag down to expand to all rows
                    You now have a dynamic link to the txt file. It will show a 0 for all empty positions in the txt-file.
                    Upside of this: when you re-export you can overwrite the original file, and easily batch upgrade your excel sheet by simply opening it.
                    btw, there are some things to consider:
                    - If more rows are added in your schedule they don't automatically show up in Excel. I usually put in more then enough rows which will fill all redundant cells with 0. When I need to print, save as, remove links and replace all 0's with blank space.
                    - It's a one way ticket. To get the data back into Revit, you'll need external software.
                    - It's currently not possible to export multiple schedules at once.
