I would like to put only "Dimension Leader" without text
    Is there any way to put only Leader without text in Revit?
    Actually, I would like to do as shown in attachment.
    See attachment. This was from another forum years ago I think.
    Just place it as a 'Symbol' - set number of leaders to 1.
    Author of What Revit Wants
      Wow..
      It really works.
      Thank you so much, Luke
        Can we have the arrow on both sides?
          Sadly the way this work around works wont give you arrows on both sides. You can however mirror the arrow. Its a work arround for a work arround.
          -Alex Cunningham
            useful post, thanks
              thanks Luke. very useful.
              Kevin
              I think I am finally getting the hang of this revit stuff.
              Revit never cooperates when you're in a hurry
                You could draw 2 really small Thin Lines, Pull a dimension off those lines, and override the dim text. Then you can have arrows on both sides. Just make sure your Witness Extension line is set to 0"
                  If your annotation is about always the same length and on 1 line only, you could draw some invisible lines in your generic annotation to force the attachment of the leader.
                  Alexandre Cantin
