Steel tonnage cautions
    This thread is a reply to a blog feed that was just posted.
    Here is my reply to that blog:
    The tonnage should be calculated using the Cut Length parameter, not the Length parameter. Yes, the value of "Length" will stay the same after the beam is cut by Opening by face or by Reference plane, as you said, but Cut Length will report the correct new length. See attached.
    Last edited by Alfredo Medina; September 27, 2011, 02:17 AM. Reason: Replying to blogs was disabled, unfortunately. :(
    True... And frankly, this has always been the case. Also when scheduling beam length. Slight brainfreeze from the author (who is normally very well informed)?
      Blog post is gone now...
      You can also use Volume x 7.8 which will caculate a tonnage based on the medium level detail solid geometry volume
      Revit BLOGGAGE
      http://www.revic.org.au
        Ouch!
        You guys were quick to pick this up....
        Total brain freeze.... and shortly after realised the solution and removed the post from the blog.
        Note to self for the future - explore all options and explore them again before blogging.
        Regards
        Glenn
        Check out my Revit blog - http://revitst.blogspot.com
          LOL, no problem... Happens to all of us from time to time.
          You could also post a question about it here... :laugh:
            Is that metirc?
            -Alex Cunningham
              That would never have happened to me
              Glenn, the original blog post was fetched here - Do you want me to delete that as well, or would you rather edit the post?
                Ouch! ... You guys were quick to pick this up....
                Well, isn't it good to know that here at Revitforum we do read the blogs, and we read them carefully?
                  I think he was just testing us... Alf, you made us pass :bb:
                    Originally posted by Alex Cunningham View Post
                    Is that metirc?
                    Yep, Tonne not 'Ton'
                    so Volumne-m^3 x (density-steel=7.8, or 7.82 to be more precise)
                    Revit BLOGGAGE
