Modifying existing slab boundary with slab edge
    Hello!I have an issue to solve and I hope someone of you can help me.I'd like to modify the foundation slab boundary, where I placed also a slab edge. If I try to edit the slab sketch and modify the original boundary, Revit gets me an error message "Could not create Slab Edge" and it suggests to delete the elements.The problem is, that I have already drawn the reinforcement for the hole project and I don't want to lost all the work already done.Have you any suggestion how to solve this issue?
    did you try to align the edge to the slab and lock it? give it a try see does it like that?
      hi wpnc79,
      Try to do it in model inplace.
      Dhilip Seshan
      +91 8124181665
      www.dhilipseshan.n.nu
        That error generally occurs because Revit can't resolve the shape, most likely because you have a segment of your slab that is smaller than the actual profile. If you remove that segment of the slab edge, then adjust your sketch you should be OK.
        chad
