I don't know how to solve this
    As attached, there are some vertical lines in blue color ( is it analytical model? )despite the fact that I have joined the column to my rafter.
    Any solution and could someone explain me what is the cause of this?
    Thanks in advance.
    Yan Naing Bo
    Senior Member
    Last edited by Yan Naing Bo; September 7, 2011, 05:23 AM. Reason: Forget to attach.
    Correct this is the analytical model and these will continue up to the upper level that the column is actually referencing. If you don't want to see it, turn off the analytical model in the view.
    Chris Price
    Co Founder | BIM Manager | Product Designer | B.Arch (QUT)
    Xrev Revit API Add-ins | Revit Rants
