UC used as beam showing two lines instead one in coarse plan view
    I have a structural plan where UC section is used as beam. In plan all other beams are just a line as I want it to be. Its coarse view. The UC`s are not showing up as a line. The a re full profile in all other views as well. What could be the reason?
    You'll need to check the family geometry for visibility settings
      I think some issues with old 2014 families we are using. I tested it with new 2018 family and it works perfect. Standard Revit families were modified to suit our use.
