360 radial array constraint
    hey yall,
    I was radial arraying an object (move to second) with the center of rotation that is not on the object. I proceeded to continue my arraying by typing in 360 into the angle of my choice and defined the number to 4.
    However, only 3 of the 4 objects showed up....
    I figured this would be extremely problematic if you want to radial array chairs around a round table...
    Thanks again for your time!
    found a solution to this, when you edit the group and move it, the 4th object shows up... but after you do that, the four objects are no longer grouped
      Could you post an example?
