Hi there,
Could someone please tell me, how to get the corret "cut length" of a steel column into schedule without making all the families around? It seems that with OOTB steel column family and OOTB steel connections it still cant give me the correct length? The column lenght is 2780mm, but when I put steel connections in, it should decrease to 2658mm (column length - steel connections). But still in schedules it shows the number on 2780. Apparently with steel beams and connections Revit understands it and subtracts connections length from beam length, but columns are different. Why is it so and how to solve it without making all new families but using OOTBs? Would like to attach an image but cant find where to.
Thanks
Olav
Thanks
Olav
