How can i change linetype of the internal wall edge .....
    How to change the internal wall lines that are attached to the slab into HIDDEN Lines.
    In the attached view, I would like to change all the wall and slab lines within the red colour area to hidden lines since they won't be seen from plan view.
    I just know how to change the whole wall (means both external and internal wall lines )..
    please someone kinldy advise
    Set your view to hidden lines instead of wireframe?
    Or else you can use the Linework tool and manually override.
      Thank you mdradvies,
      It can be done by Linework tool.
      But when i use hidden lines instead of wireframe, all the frames disappear in my view, don't know why?
      One problem is the hatch boundry can't be change to hidden line.
      Actually, i want to hide the hatch boundary as well, is there any way to solve this?
      thank you very much.
        I cannot tell from your picture if your hatch boundary is a filled region. If it is, you change the outline of it by choosing the filled region, then clicking <Edit Sketch> ... the sketch lines are purple. Choose the outlines and change their linetype.
        If the hatch is a surface pattern, you're going to need to edit the cut (or projection) lines of the objects themselves.
        Leanne Zaras, CDT, LEED AP
          Could you post (a part of) the file? It's kinda hard to answer these questions from a single picture...
            I can change it to hidden line now as per LeanneZ's suggestion.
            Since my hatches Filled-Region.
            Thank you all ...
              Hi there,
              Is it possible that you have to set your view range to below the frames? cutplan is then above slab, but viewing down underneath slab.
              That could give a result of hidden lines.
              Greetz Bross.
              http://bross.webklik.nl/page/homepage
              www.vanbragtbv.nl
