Probelm Opening Revit Model
    Hi All
    I cannot open a Revit model. The model starts updating and when it gets to 64% it stops for a short while then falls out (Revit would stay open but the model and its upgrade process would be gone).
    I have verified that the model is up to date and working.
    The model was upgraded from 2015 to 2017 and I am trying to upgrade it to 2018. I heard there was a bit of an issue with upgrading models for more than 3 years but never found a forum with a solution.
    Any Ideas?:banghead:
    Have you tried opening it in 2017 with the Audit box checked?
    Also, dig through your 2018 Journal files to see if there's a clue just before it crashes.
    Dave Plumb
    BWBR Architects; St Paul, MN
      It Opens in 2017 but all my work is on a 2018 model so I can't check my levels.
      I haven't worked with Journals much copied and pasted the last last few Journals lines
      ' 1:< GUI Resource Usage GDI: Avail 9640, Used 360, User: Used 341
      ' 1:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
      ' 1:< RAM Statistics: 6912 / 16245 1749=InUse 2043=Peak
      ' 1:< VM Statistics: 134181401 / 134217727 1558=InUse 1851=Peak
      ' 1.372650!!! 2:!!!BIG_GAP [Cloud]standardOpenDocumentFile
      ' 47.593832-- 1:<<[Cloud]standardOpenDocumentFile
