Unable to load Keynote
    Keynote.PNG Hi,
    Please kindly advise how to solve the attached problem.
    Furthermore, any shortcut to put Markings to relevent objects such as Beam / Wall / so on.
    In my current project, i need to use Different types of walls in various height rather than Beam.
    How could i put the Marking that will attached to the related substances ( walls ).
    Thanks.
    Hi Yan Naing Bo,
    The error message is due to the fact that Revit cannot locate the keynotes.txt file. Either it has no been created, or the path has somehow been messed up.
    Annotate tab - Tag drop down button bottom of tag field - keynoting Settings: Set the correct path to keynotes.txt file.
    Within keynotes, assuming that the information is within the elements, you can keynote an element or material as you wish.
    Cheers,
    Ian
    Ian Kidston
    http://allextensions.com.au
