takeoff specific area
    Dear Friends:
    Is there a way to calculate the take-offs of some material, of one specific area of the project.
    for example, if you see the image below.
    i want to know the takeoffs of beams and roofs, considering, that if i cut a Beam or roof, i only want the volume of the beam that is in the red polygon.
    Thanks
    Add a parameter called something like "zone" and filter by it would be the best way I could imagine doing this.
    Michael
    Canberra, Australia
      Welcome to the forum.
      One possible solution is this: break up your project in phases. For example, that portion could be "Building A". Change that building to that phase. Run a Material Take-off schedule, select a category, such as "Structural framing", and then from the Phase drop down menu, select "Building A".
        First part is doable. I would go with the phases, like Alf suggested.
        Second part isn't. You cannot have a part of an element calculated and another part not calculated.
          Thanks for the suggestions.
          I think the phases is a good idea, but i need to divide some elements. If i Can´t get the takeoff only cutting the element by selection.
          Is there a way to divide the elements, for example i want to divide the beams in three similar parts, and the slabs in nine parts.
            Do you think is it posible if i create some task or macro?
              you can divide slab, floors, walls and plan roofs by making Parts of them, then divide the part.
              I use this for the same purpose as yours, just think a beam should not be divided maybe, construction thinking?
              Julien
              P. DAC
                Julien, but can you create parts along the length of an object? like dividing a beam that is 60 feet long in 2 or 3 parts? I understand that Parts refers to the components of the objects, doesn't it?
                  beams can`t be, but a floor /wall/roof component can be splited in more parts if you want.
                    Phasing is the way to go for this solution.
