Steel Rebar Diameter
  • Nsync
    started a topic Steel Rebar Diameter
    I want to use rebar with diameters 10, 12, 16, 18, 20, 22 how can i do that?
    and if the only way to do that is by duplicating any existing loaded diameter, how can i get the standard properties for the new diameter like (standard bend diameter, standard hook bend diameter, stirrup/tie bend diameter)
