Rebar display
    Rebar display
    Hi all,
    In the image provided you can see a rebar stirup in plan view.
    The issue is that part of the rebar is displaying as intended (the purple part) since it is defined so with the rebar subcategory. The other part that is showing in green is the problem. I have no idea why it's showing as general setting for rebar in projection.
    What modifications do I need to make to get the rebar to display as intended, taking the settings form rebar subcategory.
    Thank you for your time and help.
    Easy things are not worth the effort
    http://www.teamcad.rs/
    Adjust the Plan View View Range? You might be cutting thru the Stirrup?
    Dwane
      This is Revit, it's never that simple https://www.revitforum.org/images/sm...tom/screwy.gif The display is fine if it's only one bar, the moment I change to a set, no matter the layout rule, it gets messed up... Thx
