IFC - how to export length instead of cut length on framing
    Hi im trying to export steel structure to SCIA Engineer 2009 via IFC 2x3,
    the problem is framing (beams and bracing) are exported as physical model instead of analytical. So instead of joining the column in the analytical point all the beams hang in the air. Check out the screenshot i attached to this forum.
    There are no options on the Engineer side so i have to modify the IFC settings (mapping etc) on the Revit side.
    Anyone has some suitable IFC Class Mapping file or default template for IFC?
    IFC will not export lenght, it will only export cut lenght. There are two solutions to this, one is to extend all of end offsets in Revit or use an extend type tool in the product you are going to...ie Tekla.
      Thanks mate,
      always good to know i've been trying to do the impossible for a couple hours )
