Problem in creating Floor in different level @ the same floor
    In my Level-1 Plan, there are four different levels : +375 , + 400 , +425 & + 825.
    I need to show all these Structural Slab Levels together with the required Slab Markings.
    But when i create the floors, the slab markings appear at all levels except +825.
    And it prompts that the level is set to the default once i have created +825 level slab.
    I can view it in section.
    Any idea to solve this.
    Have you looked into creating a Plan Region for your +825 level?
    Leanne Zaras, CDT, LEED AP
      Hi LeanneZ,
      It's solved by changing the CUT PLANE OFFSET under View Range.
      We can find the View Range under " View\Plan View\ Plan Region" as you suggested.
      As well as under Properties .
      My default setting of Cut Plane Offset is 300 and Top Offset is about 700.
      Once I changed Cut Plane Offset to 825 and Top Offset to 1000, I can view all the slab markings at any level.
      Thank you.
