Problem with the defusing of a wall's analytic model
    When I deselect the box "activate the model analytic", the wall's model analytic still appear.
    Is someone knows from what this problem come?
    Thanks!
    Check the Visibility / Graphic Overrides and / or the Detail Level of the View. Might be one of those overriding the View settings.
      In fact, there is only one wall's model analytic which doesn't disappear. It's ok for the others. So I don't know where is the problem...
        Weird. Do you by any chance have the Detail Level set to coarse? If so, you could select the wall and check the properties to see whether there is a coarse scale override (although I don't think this should affect the analytical presentation)
          It unfortunately doesn't affect the analytical presentation...
