wall with dotted lines
    I'm working on a Revit model and more precisely on its analytic model. Some of the walls are drown with dotted lines.
    Is someone knows what does that mean?
    How can I do to modify these walls in order to have "normal" lines?
    Thanks in advance!
    Wild guess: select the wall, look in the properties and search for fields "Phase Created" and "Phase Demolished". Are they the same? This representation means (in the OOTB templates) that you have a "temporary" (aka created and demolished in the same phase) element. Set the Phase Demolished to None and you should be fine.
