How Do I Change Default Discipline When Creating New Plan
    When I create new levels and then turn them into plan views the default discipline for these plans is Architectural. How do i change this so the default discipline is structural?
    Thanks all..
    Are you using Revit Structure? To my best knowledge this should default to Structural...
    Or create a standard view template to apply. Won't be automatic but it'll let you preset everything and not just the discipline.
      For the OOTB template the default setting even for Structure will set a new view to Architectural
      You need to create a view template with a discipline of structural active, you can then apply to any plan view and check the option to "apply template to new views of same type"
      Once you have these default template applied, all new plan views will have the discipline of the view template applied
      Revit BLOGGAGE
      http://www.revic.org.au
