level colors
    level colors
    here in the Netherlands we use very often foundation piles, prefab or site drilled. For these we have created fine working families and coding.
    Problem is only the bottom level of the piles, in many cases there are several different bottom levels for the piles.
    This is making the checking a real nightmare.
    Is there a way to create a colorfill or area or whatever to make it easy to see what group of piles is sitting at a certain level and another group on a different level?
    Jan
    are you using actual "Levels" in your model to attach the base of the foundations?
    Leanne Zaras, CDT, LEED AP
      not at this moment.
      We have in the past but that becomes quite messy (sometimes 5, 6, 7 or more levels as close as 0,5m. apart).
      Piles are now stuck at the base level (0) offset to the bottom of the foundation.
        Filters will allow you to override graphics of certain elements for the given view based on the filter criteria. In this case pile length or pile base level
        Geert Vennix, architecte
        www.geertvennix.eu
