Problem with the positioning of the analytic model
I'm working on a wall and a slab and I've got a problem with the posiotioning of the analytic model of the slab. I click on 'automatic detection' on 'horizontal projection' but the slab's analytic model doesn't move. I didn't draw the projet so it may be an option add that I don't see.
Can someone help me?
Are you going to be using the analytical model for export to an analysis software? If you aren't then I would not worry about the analytical mode what so ever. It does not print and does not effect your geometry in any way. I have it all off in my view templates.
François, if you create an analysis model in your analysis program, and import it into a new Revit model, where is the analytical line for the slab?
For all my slabs, I see the (brown) line at the top surface of my slab. Is this not where yours is located? Is this not where you need to see yours? I'm not sure that I can relocate that line.
(I'm currently using RST2011, but I could check in RST2012 if you need me to.)
Leanne Zaras, CDT, LEED AP AutoCAD 2010 Certified Professional / Revit Architecture 2012 Certified Professional / Revit Structure 2015 Certified Professional ACAD2021, RST2014-2021 / Windows 10, 64-bit
Hi François, I guess we need a snapshot or the file you have problems with. you can save a part of your project by making a group from some elements, and when group is done, choose link as a new file. you should post this new file here so that we can help.
waiting for that, is that a floor or a slab? is it at the top of the wall or at the bottom? What I have with RST 2012 is that analytical edges for floors are at the core axis of the bearing elements, walls in fact.
Julien "Au royaume des aveugles, les borgnes sont mal vus!"
P. DAC Follow me on Twitter @Jbenoit44 - Blog: http://aecuandme.wordpress.com/
Hi everybody,
Thank you for your time,
I send you a screenshot of my problem.
The question is for a slab and a floor because one is at the bottom of the wall and the other at the top.
In fact, I'd like the blue line to be superimpose on the red one. I have try to select 'Automatic detection' for 'horizontal projection' (analytic model) but the blue line don't move.
If you see no solution of this problem, I have find another way which is the modification of the sketch line. Indeed, the blue line 'move' with the sketch line, so this solution will modify the solid geometry but it's not a big deal because I have to only use the Robot export file.
Hi François,
after testing this, I've found that only the analytical line for walls can be moved. slab analytical line is always on the edge.
so if you select the walls, and set alignment method to projection, and after that set the projection to exterior face, the analytical red line will be aligned with the edge of the slab.
hope this helps.
I dont really use the analytical models for anything, but is the slab a "foundation slab"?
you may find that a floor operates differently and the foundation slab will have very rigid and locked down analytical points.
This has been made a little easier in 2012, but in 2011 you need to edit the sketch of the floor, select a sketch line and set the projection parameter to auto detect. If the floor AM still does not move check the AM tolerances in the Structural Settings dialog.Hope this helps.
Erik Snell, P.E.
Factory Worker (Principal User Experience Designer) I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
Thank you TheViking, your sentence "If the floor AM still does not move check the AM tolerances in the Structural Settings dialog.Hope this helps" leads me to the solution!
Thanks to everyone for your help!
In the past I have trialled E-Tabs, and found that the interoperability wasn't great, whilst we could import an E-Tabs model into Revit, the member sizes...
Not sure how to fix this model issue i can not get the analytical model to show unhid the analytical model on the bottom left icon all the VG items are...
I've never seen this before. I have 3 pieces of specialty equipment that cut my slab. I've used these families for years, but I'm getting errors in...
June 10, 2013, 03:50 PM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
