Paint the Face of generic model
    I need to paint the face of a number of generic models (for a meeting presentation) in the project.
    I have no idea why, but I can't select any face after selecting the paint tool.
    To be clear..I can't select any face of the GM's.....it will select slabs and column faces.
    I found I can open the GM family and paint any face in the editor environment.
    But can't even select a face in the project environment?
    What gives?
    I certainly don't want to open every family just to apply paint (and worse have to open them all again to UN-paint later)
    Also...once painted (if GM faces CAN be painted, and I can't imagine why they couldn't be)...is it possible to apply a filter so the paint is NOT shown (when I need to turn it off) ??
    Thanks in advance!
    "Two possibilities exist. Either we are alone in the universe, or we are not.
    Both are equally terrifying."
    - Arthur C Clarke
    You cant do it on families, in the project environment. Categories dont matter. You can paint it in the family editor with a PARAMETER though, and that will have the same effect if you use instance parameters.
    EDIT: You say youve done it on columns. If you can, then im wrong about it not working on ALL families. But ive never seen it work on a component. Are the columns built from walls? or....
      I couldn't get the paint tool to work on a GM or column (structural or architectural.)
      chad
        Aaron - Thanks for the quick reply and confirmation of the no painting family face in the project. (I wonder why?)
        When you say do it in the editor with a parameter, I take it you're referring to a simple visibilty parameter...either on or off correct?
        Lastly, with columns - dude, my level of revit experience MIGHT be equal to yours when you're in the middle of REM sleep.....
        Some of the stuff you guys talk about on here blows me away, and I wish I understood it - I'm just glad to be able to muddle thru what I need to do to hit a submittal date with a presentable set.
        So at first, when you kinda "questioned it" - I thought maybe I just thought I had painted a column face before. So I tried it and it worked.
        I just use the columns that come in the box.
        Thanks again for the reply.
        - Arthur C Clarke
          Paints for me...not that I ever have a need to do so.
          - Arthur C Clarke
            In the family editor you can use the Paint tool to paint surfaces with a material parameter. This way you can change the material of the surfaces you need when you need to.
              weird. I tried it again and still nothing. :crazy:
              chad
                Andrew,
                Can you (or someone) please expand on this? What's the process?
                Sounds like it would work perfectly for what I need.
                Thanks
                [Edit] nope...on/off visibility didn't work...can't select just the paint.
                I figured that would be too easy
                Defiant1
                Senior Member
                - Arthur C Clarke
                  Parametric painted finishes in families are explained in this thread.
                  Julie Kidder
                  Architect + BIM Director
