Shared Parameters
    Shared Parameters
    Dear All,
    I have worked a concrete building in Revit structure 2012 and have put all the required reinforcement into the columns, beams and footings. Now what I need is complete schedules. However, when I create, for example, columns schedule, I don't see any field for top rebar, bottom rebar, face rebar, stirrups spacing, and other information.
    I know I have to make shared parameters and I have successfully defined those parameters and have loaded them into the beam family of Revit. What I don't know is how to make Revit Structure enter, for example, the spacing of stirrups or the number of top or bottom rebar, into the schedule field.
    I would appreciate your assistance regarding this issue.
    Thanks a million
    Regards,
    Ali Akbar Shaikhzadeh
    Out on a limb here, but you might want to check if the shared parameters are loaded in the project file. This isn't automatically the case. Go to Manage Tab > Project Parameters. If the SP's aren't listed there you need to Add them and assign to the correct Category. After this you can use them in the Schedules.
