Lucian, thank you for changing the in-line attachments for uploads.
The problem with your solution is that you are doing this drop in the height of the plaster or finish layer with detail lines. That's not very "BIM", because then this drop will not exist in any other views. The recommended solution in this case is to "model it as you will build it", which is to create that finish and the drop, with, either a thin floor with just those two layers, or with a ceiling. By doing this, all your sections will look correct, without the need to add any detail lines or masking regions.
As for the other part, the vertical piece, check this other thread, where there are different solutions available:
However, if you still want to keep it as a 2D solution, you can get rid of that portion of the slab by using View > Edit cut profile, as shown in this illustration:
What I'm trying to do is "simulate" a prefabricated channel for a pipe under the foundation slab. In my section view, that channel is "in front" of the 10cm plain concrete under the foundation slab. You can see that channel "sketched" in ".Plan radier".
Because there where only 2 drawings, I hoped it would take less time to draw the channel with lines then model it in 3D.
So what I was trying to do in the above example, was to "mask" the 10cm plain concrete under the foundation slab with a white band.
Then, see the solution with Edit Cut profile above. Then you can add the line work. Another way to cut that portion is to use a masking region with invisible lines, but maybe the Edit Cut profile solution is better in this case.
As is common for foundation slabs, I want to haunch the slab over the footings.
I know Revit has a slab haunch family/tool, but as the foundations...
September 30, 2015, 02:47 PM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
