Bending a HSS beam for smooth connection
    Hello everyone,
    I am doing a project in school trying to recreate a pedestrian bridge at UNT. My question is: Looking at the HSS beam in the picture is there a way on Revit Structure to bend this Hollow tube steel beam to make a smooth connection. The beam goes up about 4.9% to a point than goes down -4.3%. Or is my only option to make many small beams to make it appear its a smooth connection.
    Thank you in advance
    Is this two straight beams that come together in an inverted V? Or is this a radiused beam?
    If it's two beams, then use two beam at different slopes.
    If it's one radiused beam, then you can place it, along a radius, in an elevation view.
    If what you're trying to do is re-create what is in the photograph, you may also want to look into Structural Trusses.
    Leanne Zaras, CDT, LEED AP
      Thank you for your quick response
      It is one radiused bean. My apologies but im a newbie, can you explain how i place it along a radius?
        To make a arched beam in Revit you need to have the arch drawn in some other form first, either a model line or arched roof. You can then use the "Pick Lines" tool when drawing your beam and choose the arched line/surface. Please note that you will not be able to adjust this arches radius after you place it, so get it nailed down the first time.
        -Alex Cunningham
          This is a cool thread. I have not yet had the opportunity to make a curved beam. So I gave this a whirl. Using Revit 2013 I followed Alex's instructions. I cut a section perpendicular to a grid line. Drew a curved Model line by picking said grid line as my reference plane. Then picked that line to model my beam. I would like to amend Alex's statement about the adjustable radius. I was able to change the radius once the beam was modeled. After you click on the beam, a grip appears at the center point of the beam's z-Direction Justification. You can either click and drag to any point or add a dimensional radius. You can also snap to other elements, such as Reference Planes and other beams.
            I haven't done this in 2012 even... last time was 2011... looks like you now can change it after its been placed. COOL :beer:
            -Alex Cunningham
