Where did my metal deck go?
    We have a 6 1/4" slab --- 3 1/4" conc. on 3" composite metal deck.
    When I cut a section, I should see the deck profile. If I move the section around the slab, sometimes I see the deck, sometimes I don't. Where do you think my metal deck is hiding? (even turned off ALL links and set to Discipline: Structural)
    Any ideas?
    Now it's just playing with me. The place I originally cut a section (where the deck profile *was* showing, the deck no longer shows... going to try to get screenshots to post...)
    Got out of model, opened with Audit, and still having the issue...
    Deck Plan A shows where I cut Section A; the deck shows as I expect.
    Deck Plan B shows the EXACT SAME section cut, just moved to the left; my deck is not showing. I stretched the crop box up so I could see if the deck disappeared in the third floor also. This time it did not, but sometimes it does.
    Leanne Zaras, CDT, LEED AP
    Is your deck direction correct? Is it assigned in both floors going the same direction?
    -Alex Cunningham
      yes. I checked the deck direction. This is a large slab that covers 1/2 the building's floor plate. That's why I cut one section and moved it around (within the same slab's boundaries) and discovered the misbehavior.
        Very strange. I can not duplicate the issue you are describing. Does it effect the printing at all? Maybe its just not regenerating the graphics on your screen???
        -Alex Cunningham
          yes. The issue does affect printing.
            First make sure that you deck is definitely perpendicular or parallel to the grids
            But following that I have often seen large areas of composite slab behave like this, especially with complex sketch lines.
            If you break into a few smaller sketches it should work fine
            Out of interest does this floor sketch fit on one sheet?
            Revit BLOGGAGE
            http://www.revic.org.au
              Interesting thought about the slab not completely fitting on one sheet... But, no luck. This (misbehaving) slab fits on one sheet; the one that is behaving correctly *does* cross two sheets.
              I think you're correct that it may have something to do with the angle of the deck span and the complexity of the sketch. If it comes down to it, I may go ahead and break the slab into several pieces.
              For S's and giggles, I cut a section at the other side of the slab. In section view, the deck profile showed up. I stretched the crop box (toward the side of the slab where I want my section.) As I move that edge of the crop box, the deck profile appears and disappears. I cannot determine where it's going to decide to re-appear. I played with both edges of the crop box and I'm still at a loss for my original section cut.
              I just think it's kind of a pain to have to go to that section EVERY DAY and make sure my deck profile is going to show up before I print. Blah!
                Have you filed a support request?
                Erik Snell, P.E.
                Factory Worker (Principal User Experience Designer)
                I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
                  Is your metal deck direction correct?
                  is it assigned in both floors going to the same direction?
                  blood sugar monitors
                    see posts #2 and #3 above.
                    This is a 6-month old post. At the time we were using RST2011. I did not contact Adesk on this issue. If you're also having an issue with this, look at Ben-May's post #6. I ended up breaking my "complex" slab (not fully rectangular, with jogs and angles all over the place) into smaller, more rectangular-like portions. This solved my issue.
