difference between new project and project template
    hey all
    what is the difference between project and project template when starting a new p.
    cheers
    One starts you off in a project (.rvt) environment, (set by the template of your choice in the section of the dialog above) the other starts you off in a template (.rte) environment.... you have the same choice as before, to start from blank, on top of another template - and from there you can then go on define a template further.
    In essence, they've very much the same thing (when it comes to saving what you've actually done) but think of it as, the former (project) is for starting new models, the latter (project template) is for starting/developing a template.
