Precast T-Beam and block flooring system family?
    Hi! I new to create a family for this kind of flooring system (please see the attached image), someone can help me? Or someone has this family created in library?
    Best regards, Yeudin.
    Hi!
    Maybe can you begin by creating your precast T-beam by modify a concrete beam family.
    For the block flooring system, you can try to use the precast-hollow core slab family to create your own blocks?
    I had to create this kind of family with the Delta beam Peikko system in the past and it's where I begin.
    Hoping I have help you!
    Alex Fugère
    technologue en génie civil
    Douglas Consultants inc.
    www.douglasconsultants.ca
      As Alex says, use beams families, then use them in 2 beam systems with appropriate dimensions. If you need to schedule the blocks, do the math in a calculated value in the schedule.
      Julien
      P. DAC
        Thanks for the precision Julien!
        Alex Fugère
          Thanks! I'll try it, and maybe later I'll upload the families.....
