Steel Pipe Pile with Beveled End?
    I'm designing a pipe pile foundation with steel cap plate and wonder if it's possible to create the pipe with one end beveled? Currently I'm using a sloped pile and a void extrusion on top but it'll hide the cap plate as well.
    it shouldnt hide the cap plate unless you also tell it to cut the cap plate...
      You could use a structural column instead of a structural foundation family. Make the column slanted, and change the top/base cut style to horizontal.
      Tony Perez @Twitter
      Senior Structural Designer
      Tesla Gigafactory - Austin
      • PIPE : steel+plastic=isssue
        hi
        i'm working on projects w<here we use PVC and steel (stainless steel nowadays)
        some jonctions are made between theses two kind of pipes...
        September 20, 2019, 06:47 PM
      • carbon steel Pipe Fitting Fmily
        hi
        I need to have Revit carbon steel Pipe Fitting Family
        could any friends help me please?
        thanks a lot
        March 8, 2017, 02:47 PM
      • Connections Pipework
        new to revit MEP on first project trying to connect pipework to boiler, I have added a potterton boiler, has connections
        I am trying to connect...
        May 22, 2014, 11:21 AM
      • Steel Pipe Manufacturers
        I'm after a list of manufacturers who have a good library of pipework available to download.
        Ideally I'm after steel pipework in particular....
        January 9, 2018, 10:23 AM
      • Swept pipework
        Does anyone know how I create this sort of swept pipework? At the moment I cant only create straight pipework with connections either end but apparently...
        January 13, 2015, 01:23 PM
