revit mep problem
    revit mep problem
    I have a problem, and I wonder is it possible to solve it.
    I was created a space, and I created a zone, and in zone i define a Air per change , and i was a define a volume this zone.
    We know that is : air per change multiplie with Volume this zone= gives me air flow who i need to give a zone in m3/h.
    is it possible when i clik on air terminals supply difuser , supply difuser automat. calculate this value, and when i put supply difuser on diffrent zone, this value change.
    i feel Diffuser may not calculate the flow of air.Designer have to define the air flow required in the Zone than to particular space (looking into the use of space).
    Sonam
      That's what I thought, thank you very much.
      • Setting Fresh Air Temperature
        Dear All,
        i have a mechanical system which described bellow:
        Fresh air comes from HRV (Heat Recovery Unit) unit.
        Heating Cooling is...
        February 18, 2015, 07:21 AM
      • Duct Systems
        I'm curious as to the proper way to do this.
        System description:
        Outside air through ERVs to bring it up to a minimum temperature...
        January 9, 2017, 07:39 PM
      • Outside Air System
        There is a bit of controversy here as to what an Outside Air system is to be based on. This is the air that goes from a louver via plenum/duct to the...
        August 26, 2014, 07:16 PM
      • Air Terminal Flow Halved - two connectors.
        Hi all,
        Am I doing something terribly wrong?
        I've received a project with an Air Terminal family that has two connectors.
        August 12, 2015, 12:02 PM
      • Shared parameters between categories
        Hi All,
        I have a questions regarding the „reading“ of parameters between categories.
        For instance, inside my Air Terminal...
        April 4, 2017, 11:30 AM
