Sub-Discipline
    Sub-Discipline
    In Revit MEP 2011, I can usually create new views, then choose a discipline and a sub-discipline in the 'properties' window. This then groups them accordingly
    This time, I have opened a file previously created on Revit Architecture, on MEP. All the views are under 'Architectural' in the project browser. When I create new views and try to assign them a discipline and sub-discipline, I find that the 'sub-discipline' in the properties window has disappeared.
    What could be happening?
    Any help will be really appreciated. Im very new to Revit
    Nash
    Lovi,
    I created a new project file using an arch template and get the same result. Maybe it's a limitation of the arch template? Anyone else able to make sub-disciplines in an arch file?
      Sub discipline is specific to mep. You just need to add a project parameter for views under the manage panel. Then you need to customize your project browser to sort by this parameter
      Revit BLOGGAGE
      http://www.revic.org.au
        Im not sure what Im doing here.. could you explain? I went to Project Parameters.. didnt really understand what it was about
          Sorry have been offline, Simply goto Project Parameters, and follow the steps below
          • Add Parameter
          • Under Categories choose "Views"
          • Give the parameter a name "Sub-Discipline"
          • Type of Parameter should be "Text"
          • Group Parameter Under can be whatever you like and can be changed aferwards but I would suggest "Graphics"
          • Keep "Instance" parameter ticked
          You will now have a parameter for every view which will need to be populated
          Then you just need to create the Browser Organization :thumbsup:
          Revit BLOGGAGE
            Ben-May it worked! This is finally more organisation in my work
            Cheers dude!
