I'm on the architectural side of things playing with RME so i'm not really too familiar with this (although have read the shortcomings of sloping pipe):
I'm having trouble getting a clean WYE connection off the sloped main. It seems to add all these extra fittings when I try to slope a branch off of it (un-sloped as well).
The only way I can get this to work is using Connect Into directly from the fixture to the main. It only goes in a straight line and it doesn't slope (I have to slope it afterward). I then split straight branch pipe, pull it back and angle it in plan and move it down the main run, then trim it back to the straight branch.
Although I can get to the desired result, I'd like to be able to draw directly off the main and then to the fixture without all these extra fittings. First two images are how I want it to look, the next two are the result of drawing directly off the main sanitary line.
