Sanitary piping network not picking up systems
    Hi guys, Looking for some help regarding piping systems (predominantly sanitary).
    The problem i'm having is that I have ended up with way too many systems and i'm attempting to condense them so that I can have as few systems as possible.
    The majority of my sanitary piping is in the one continuous network of pipes yet Revit has created many individual systems, ie. my main runs and branches have different systems and I can't seem to find a way to assimilate them into the one system.
    Does anybody have a good method for removing the unnecessary systems and having the one major system cascade through to all the connected piping???
    You can go through and directly delete a system, but you can't move the equipment and piping on one system to another by this method. You could go through and move the equipment from the systems you don't want, to the system you do want. That way all of the connected piping will get transferred to the system you want.
    • Piping System
      I am currently a student using REVIT and I need help with the piping system. I created a piping system and when I did so, the sprinklers disappeared....
      August 5, 2017, 02:56 PM
    • water treatment - what system clasiffication to use??
      hi
      i'm building a template for waste water and drinking water plants.
      Revit is more focus on HVAC work and the systems classification are...
      August 21, 2019, 08:24 AM
    • Plumbing fixture on 2 systems?
      Im just looking at my system browser and one of WHBs are on 2 systems one named system and 1 unsigned system? - both sanitary systems
      how...
      October 10, 2013, 02:35 PM
    • Keep different systems piping name
      Hi! I have 3 systems piping name (Sanitary 1, Sanitary 2 and Sanitary 3) in my project. When I continue my piping for Sanitary 2 to connect into the Sanitary...
      March 21, 2012, 05:52 PM
    • plumbing system identity
      I have a situation with plumbing system identity. Here is what's happening. I have cold water, hot and hot water return systems. Somewhere down the line...
      May 2, 2016, 03:22 PM
